주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anbernic RG353V Screen Replacement
필요한 것
  1. Anbernic RG353V Screen Replacement, Circuit Board: 1 단계, 이미지 3개 중 1개 Anbernic RG353V Screen Replacement, Circuit Board: 1 단계, 이미지 3개 중 2개 Anbernic RG353V Screen Replacement, Circuit Board: 1 단계, 이미지 3개 중 3개
    • Make sure to remove the SD cards from the device before repair. Push them inwards so that they pop out of their respective slots.
    • Use a 2 mm Hex screwdriver to remove the six 7 mm screws from the back case of the handheld game.
    • Use an opening tool to pry the top and bottom of the game apart. Work the tool around the perimeter of the device between the seam to release the snap tabs.
    • Separate the top and bottom cases gently.
    • Don't pull them apart as they are connected by cables and pulling them could rip the wires and damage the device.
    댓글 쓰기
  2. Anbernic RG353V Screen Replacement: 2 단계, 이미지 3개 중 1개 Anbernic RG353V Screen Replacement: 2 단계, 이미지 3개 중 2개 Anbernic RG353V Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Push on alternating sides of the connector to disconnect the battery wire from the main circuit board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • To disconnect the cable coaxial cable, slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
    • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
    • Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
    • Don't try to force the connector into place or you may permanently damage it.
    • Disconnecting these wires will allow you to separate the back of the case from the front in order to work more freely.
    댓글 쓰기
  3. Anbernic RG353V Screen Replacement: 3 단계, 이미지 2개 중 1개 Anbernic RG353V Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the five 7 mm Phillips from the plate covering the bottom of the circuit board.
    • Remove the black cover.
    • The next three steps after this one can be done in any order.
    댓글 쓰기
  4. Anbernic RG353V Screen Replacement: 4 단계, 이미지 2개 중 1개 Anbernic RG353V Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #00 to remove the four 6 mm screws attaching the thumbsticks to the circuit board.
    • Use a spudger to flip up the locking flaps of the ZIF connectors.
    • Use tweezers or your fingers to gently pull the red ribbon cables out of their sockets.
    댓글 쓰기
  5. Anbernic RG353V Screen Replacement: 5 단계, 이미지 3개 중 1개 Anbernic RG353V Screen Replacement: 5 단계, 이미지 3개 중 2개 Anbernic RG353V Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the locking flap of the ZIF connector.
    • Use tweezers or your fingers to gently pull the bronze-colored ribbon cable out of its socket.
    • Use tweezers or your fingers to remove the small black ribbon cable from the socket.
    • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    댓글 쓰기
  6. Anbernic RG353V Screen Replacement: 6 단계, 이미지 2개 중 1개 Anbernic RG353V Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the four 5 mm screws that secure the circuit board to the case.
    댓글 쓰기
  7. Anbernic RG353V Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the circuit board by pulling it upward and away from the case.
    • Gently thread the two ribbon cables through the slot to avoid damage.
    댓글 쓰기
  8. Anbernic RG353V Screen Replacement, Screen: 8 단계, 이미지 2개 중 1개 Anbernic RG353V Screen Replacement, Screen: 8 단계, 이미지 2개 중 2개
    • Remove the black tape at the top of the device.
    • Make sure to keep this as you will need to put it back on later.
    • Insert the iFixit opening tool in between the case frame and the metal screen plate to separate the adhesive from each side.
    • Take your time with this step to avoid damaging the device, as the adhesive is very strong.
    댓글 쓰기
  9. Anbernic RG353V Screen Replacement: 9 단계, 이미지 3개 중 1개 Anbernic RG353V Screen Replacement: 9 단계, 이미지 3개 중 2개 Anbernic RG353V Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Press the metal plate from behind with your thumb to gently push the screen out.
    • The ribbon cables will come out along with it.
    • If the adhesive was not released sufficiently in the previous step, you may need to go back with a spudger and pry along the area to loosen the connection.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Konnor
회원 가입일: 09/09/24
712 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 20
지난 30일: 106
전체 시간: 1,882
