주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker 2.4G Wireless Mouse Battery Replacement
필요한 것
  1. Anker 2.4G Wireless Mouse Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the battery cover with a plastic opening tool, nylon spudger, or a fingernail.
    댓글 쓰기
  2. Anker 2.4G Wireless Mouse Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery with a finger nail or a nonmetal tool.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Vincent Lee
회원 가입일: 01/23/14
365 평판
안내서 3개를 작성함
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개를 작성함
2가이드 댓글
My Anker vertical wireless mouse uses 2 "AAA" batteries. It is Model TMI56G. Batteries are fresh. Dongle is new. The mouse worked fine with the dongle that was broken prior to the company sending me a replacement. The highest bar on the thumb side on the mouse comes on and glows red briefly when I turn the mouse on. There is no clear button on top of the mouse. I have Windows 10 and when I check my settings I keep getting an "ERROR CODE 10" FOR MY ANKER Mouse. My LOGITECH mouse works just fine when I plug into the same USB port. Could I have been sent the wrong dongle for my ANKER Mouse? Please advise.
Thank You,
Richard Johnson
mutantear@comcast.net
Rick Johnson - 답글 공유
Any help would be appreciated. I need to return the LOGTECH mouse I'm now using to it's owner.
Thanks,
Rick
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 57
전체 시간: 6,578
