주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker 2.4G Wireless Mouse Sensor Replacement
필요한 것
    1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: 1 단계, 이미지 1개 중 1개
      • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
      댓글 쓰기
    2. Anker 2.4G Wireless Mouse Sensor Replacement: 2 단계, 이미지 1개 중 1개
      • Using your Phillips screwdriver, remove the four screws.
      댓글 쓰기
    3. Anker 2.4G Wireless Mouse Sensor Replacement: 3 단계, 이미지 2개 중 1개 Anker 2.4G Wireless Mouse Sensor Replacement: 3 단계, 이미지 2개 중 2개
      • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
      • Make sure you are not using too much pressure, as you could warp the plastic.
      댓글 쓰기
    4. Anker 2.4G Wireless Mouse Sensor Replacement: 4 단계, 이미지 1개 중 1개
      • Disconnect the wires from the white crimping headers.
      • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
      댓글 쓰기
    5. Anker 2.4G Wireless Mouse Sensor Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the scroll wheel from the motherboard by pulling it to the left.
      • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
      댓글 쓰기
    6. Anker 2.4G Wireless Mouse Sensor Replacement: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      • Gently lift the motherboard away from the plastic housing.
      • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
      댓글 쓰기
    7. Anker 2.4G Wireless Mouse Sensor Replacement: 7 단계, 이미지 1개 중 1개
      • Desolder the six wires holding the I.C. in place to complete the sensor change.
      • Replace the broken sensor with the new sensor and solder back in place.
      • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Ryan
회원 가입일: 01/23/14
152 평판
안내서 1개를 작성함
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 53
전체 시간: 8,513
