주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker SoundCore 2 Battery Replacement
필요한 것
    1. Anker SoundCore 2 Battery Replacement, Front Panel: 1 단계, 이미지 2개 중 1개 Anker SoundCore 2 Battery Replacement, Front Panel: 1 단계, 이미지 2개 중 2개
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      댓글 쓰기
    1. Anker SoundCore 2 Battery Replacement, Battery: 2 단계, 이미지 3개 중 1개 Anker SoundCore 2 Battery Replacement, Battery: 2 단계, 이미지 3개 중 2개 Anker SoundCore 2 Battery Replacement, Battery: 2 단계, 이미지 3개 중 3개
      • Remove eight 10 mm screws from the speaker mount using a Phillips #1 screwdriver (Phillips #0 can strip the screw heads).
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Be careful not to damage the rubber gasket around the speaker mount plate.
      • Use your hand to remove the speakers. Some variants have a wire from the speaker to the board, some rest on contact pins.
      댓글 쓰기
    2. Anker SoundCore 2 Battery Replacement: 3 단계, 이미지 3개 중 1개 Anker SoundCore 2 Battery Replacement: 3 단계, 이미지 3개 중 2개 Anker SoundCore 2 Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #1 screwdriver. Some variants have 2 screws.
      • Carefully remove the bluetooth antenna wire from the left of the board. It pulls up without much pressure.
      • Flip up the motherboard to expose the battery.
      댓글 쓰기
    3. Anker SoundCore 2 Battery Replacement: 4 단계, 이미지 2개 중 1개 Anker SoundCore 2 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Use a nylon spudger to remove the battery from the speaker casing.
      • Caution: Do not use metal prying tools on a battery—these can puncture an unprotected battery, potentially causing a fire.
      • The battery is glued down so it may be difficult to remove.
      댓글 쓰기
    4. Anker SoundCore 2 Battery Replacement: 5 단계, 이미지 2개 중 1개 Anker SoundCore 2 Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Unplug the wire that connects the battery with the motherboard.
      • Battery specs: 2 x 18650 2600mAh soldered in series (to bring voltage to 7.4V).
      • Can safely be upgraded to 2 x 18650 3500mAh for additional capacity.
      • When replacing the battery, plug in the new battery where the old one was plugged in.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Tripp Lersch
회원 가입일: 01/14/21
411 평판
안내서 4개를 작성함
8가이드 댓글
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Michael Anderson - 답글 공유
7.2V, 2550 mAh, 18.36 Watt - Hour
Kang Le - 답글 공유
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
abdurreheembakir - 답글 공유
Akku SoundCore2
Kapazität 2600 mAh Leistung 19.24 Wh Spannung 7.4 V Typ Li-ion
Andreas Reheis - 답글 공유
same. i tried cleaning and drying, even an improvised other battery but nothing happens. charging only ever shows red light.
JohnLS17 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 160
지난 30일: 674
전체 시간: 25,115
