주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker Soundcore Boost A3145 Battery Replacement
필요한 것
  1. Anker Soundcore Boost A3145 Battery Replacement, Base: 1 단계, 이미지 2개 중 1개 Anker Soundcore Boost A3145 Battery Replacement, Base: 1 단계, 이미지 2개 중 2개
    • Insert a spudger between the base of the speaker and its body.
    • Along the seams of the base, begin prying at the hooks until you hear a “click”.
    • Once you get a slight lift, slowly glide the spudger throughout the base to unlatch all the hooks.
    댓글 쓰기
  2. Anker Soundcore Boost A3145 Battery Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Boost A3145 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Using the spudger, dig at the center of the speaker to pry at the adhesive keeping the remaining base attached (Utilize the image in Step 3 as a reference for where the adhesive is).
    • Some sort of heating element may help in softening the adhesive, however both excessive heat and moisture are not recommended!
    댓글 쓰기
  3. Anker Soundcore Boost A3145 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the old base up and replace the new base, relatching the new base with a “click” for each hook.
    • It is recommended that any old adhesive be cleaned off and replaced prior to reinstallation.
    댓글 쓰기
  4. Anker Soundcore Boost A3145 Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 Anker Soundcore Boost A3145 Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the eight 9 mm Phillips #0 screws from around the base plate.
    • Remove the six 6.3 mm Phillips #0 screws from around the battery cap.
    • Some screws may be underneath some adhesive from the speaker’s base.
    • Use a spudger to pry up the base plate.
    댓글 쓰기
  5. Anker Soundcore Boost A3145 Battery Replacement: 5 단계, 이미지 3개 중 1개 Anker Soundcore Boost A3145 Battery Replacement: 5 단계, 이미지 3개 중 2개 Anker Soundcore Boost A3145 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Gently pry the battery connector directly out of its socket.
    댓글 쓰기
  6. Anker Soundcore Boost A3145 Battery Replacement: 6 단계, 이미지 3개 중 1개 Anker Soundcore Boost A3145 Battery Replacement: 6 단계, 이미지 3개 중 2개 Anker Soundcore Boost A3145 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Take off the battery cover.
    • Using a spudger that's ESD-safe, remove the battery from the chassis.
    댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Minh Do
회원 가입일: 02/19/26
485 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 84
전체 시간: 144
