주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker Soundcore Motion 300 Battery Replacement
필요한 것
    1. Anker Soundcore Motion 300 Battery Replacement, Speaker Grille: 1 단계, 이미지 2개 중 1개 Anker Soundcore Motion 300 Battery Replacement, Speaker Grille: 1 단계, 이미지 2개 중 2개
      • Insert an opening tool into a seam between the grille and chassis.
      • Gently pry the grille up to begin disengaging the retaining clip.
      • Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
      댓글 쓰기
    2. Anker Soundcore Motion 300 Battery Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Motion 300 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Keep working around the edges until all the clips are loose.
      • You may hear soft clicking sounds as the clips come undone.
      댓글 쓰기
    3. Anker Soundcore Motion 300 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully remove the grille from the speaker.
      댓글 쓰기
    1. Anker Soundcore Motion 300 Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Anker Soundcore Motion 300 Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Anker Soundcore Motion 300 Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
      • Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
      댓글 쓰기
    2. Anker Soundcore Motion 300 Battery Replacement: 5 단계, 이미지 3개 중 1개 Anker Soundcore Motion 300 Battery Replacement: 5 단계, 이미지 3개 중 2개 Anker Soundcore Motion 300 Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Use an opening tool to pry up the speaker housing.
      • Set the speaker housing beside the speaker, with care not to strain the cables connected to the drivers.
      • The speaker housing may be very difficult to remove due to adhesive. If necessary, use a hairdryer to lightly heat the perimeter of the housing to loosen the adhesive.
      댓글 쓰기
    3. Anker Soundcore Motion 300 Battery Replacement: 6 단계, 이미지 3개 중 1개 Anker Soundcore Motion 300 Battery Replacement: 6 단계, 이미지 3개 중 2개 Anker Soundcore Motion 300 Battery Replacement: 6 단계, 이미지 3개 중 3개
      • Use tweezers to remove the sealant that secures the battery connector.
      • Pull the battery connector directly out of its port.
      • Lift the battery up and out of the chassis.
      댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Holly Hoffman
회원 가입일: 02/17/25
487 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 47
전체 시간: 867
