주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker Soundcore Space One Microphone Replacement
필요한 것
    1. Anker Soundcore Space One Microphone Replacement, Ear Pads: 1 단계, 이미지 1개 중 1개
      • Flip over the device so the ear pads face up.
      • This replacement guide will only cover one of the ear pads. The same exact steps apply to both.
      댓글 쓰기
    2. Anker Soundcore Space One Microphone Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Space One Microphone Replacement: 2 단계, 이미지 2개 중 2개
      • Insert a spudger (plastic or metal) between the ear pad and the driver housing (the driver housing is the outside plastic part of ear cup).
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one.
      • Pry around the ear pad in a circular path until it fully releases.
      댓글 쓰기
    3. Anker Soundcore Space One Microphone Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the ear pad from the driver housing.
      • The gray foam component shown is an additional protective component of the ear pad. You can remove it with your hands if needed, without any tools.
      댓글 쓰기
    1. Anker Soundcore Space One Microphone Replacement, Driver: 4 단계, 이미지 2개 중 1개 Anker Soundcore Space One Microphone Replacement, Driver: 4 단계, 이미지 2개 중 2개
      • Position the inside of the driver housing facing up (without the ear pad).
      • Unscrew the six 6.1 mm Phillips #00 screws from the driver housing.
      댓글 쓰기
    2. Anker Soundcore Space One Microphone Replacement: 5 단계, 이미지 2개 중 1개 Anker Soundcore Space One Microphone Replacement: 5 단계, 이미지 2개 중 2개
      • Pry around the interior plate of the driver housing with a spudger.
      • Carefully lift out the interior plate of the driver housing with a spudger to fully remove it.
      • This component has wires still connected to it, so don't be too aggressive when popping it off.
      댓글 쓰기
    3. Anker Soundcore Space One Microphone Replacement: 6 단계, 이미지 2개 중 1개 Anker Soundcore Space One Microphone Replacement: 6 단계, 이미지 2개 중 2개
      • Flip the popped-off plate component away from the ear cup.
      • Use a soldering iron in a circular path along with the seam of the glue (white lining) to separate the two components that are glued together.
      • The soldering iron is extremely hot and could burn the user if used incorrectly. Please proceed with caution.
      • Pop off this component once it has detached from the glue (a spudger may be needed for this).
      댓글 쓰기
    4. Anker Soundcore Space One Microphone Replacement: 7 단계, 이미지 2개 중 1개 Anker Soundcore Space One Microphone Replacement: 7 단계, 이미지 2개 중 2개
      • Pry the white adhesive layer around the driver component off with a spudger.
      • The actual driver is the metal disc in the center. The entire driver component includes everything inside the white lining (pictured in the second image).
      댓글 쓰기
    5. Anker Soundcore Space One Microphone Replacement: 8 단계, 이미지 2개 중 1개 Anker Soundcore Space One Microphone Replacement: 8 단계, 이미지 2개 중 2개
      • Insert a Phillips #00 screwdriver into the hole in the metal center of the actual driver.
      • Pop off the driver component.
      • You will have to replace the entire driver component pictured, since there's no given way to retrieve the actual driver. If you attempt to replace just the actual driver, it could risk damaging interior components.
      댓글 쓰기
    1. Anker Soundcore Space One Microphone Replacement, Microphone: 9 단계, 이미지 1개 중 1개
      • Locate the microphones by looking in the outside bowl area fit with wires and white spots.
      • This guide covers the microphones in the left ear cup. There's one other microphone in the right ear cup.
      댓글 쓰기
    2. Anker Soundcore Space One Microphone Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the microphones from underneath the white coverings with a spudger.
      댓글 쓰기
    3. Anker Soundcore Space One Microphone Replacement: 11 단계, 이미지 1개 중 1개
      • Pop out the microphones from underneath their white coverings.
      • The same process is done to the other two microphones
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Malcolm Hewlett
회원 가입일: 03/21/25
433 평판
안내서 4개를 작성함
UMass Dartmouth, Team 2-3, Botvin Spring 2025 UMass Dartmouth, Team 2-3, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S2G3
3 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 69
전체 시간: 742
