주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anki Vector Battery Replacement
필요한 것
    1. Anki Vector  Battery Replacement, LCD Facial Display: 1 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement, LCD Facial Display: 1 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement, LCD Facial Display: 1 단계, 이미지 3개 중 3개
      • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
      • Repeat this step on the other side.
      • The panel should pop off without much force.
      댓글 쓰기
    2. Anki Vector  Battery Replacement: 2 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 2 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
      • Lightly turn the spudger to separate the plate from Vector's head.
      • Work the spudger around the plate until it comes off.
      • Repeat this step on the the other side.
      댓글 쓰기
    3. Anki Vector  Battery Replacement: 3 단계, 이미지 2개 중 1개 Anki Vector  Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
      • Repeat this step on the opposite side.
      댓글 쓰기
    4. Anki Vector  Battery Replacement: 4 단계, 이미지 2개 중 1개 Anki Vector  Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Pull apart Vector's head. It should separate down the middle.
      • Remove the screen protector by gently pulling it free from the two face halves.
      댓글 쓰기
    5. Anki Vector  Battery Replacement: 5 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 5 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
      • Pull the LCD and speaker assembly from Vector's head.
      • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
      댓글 쓰기
    1. Anki Vector  Battery Replacement, Battery: 6 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement, Battery: 6 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement, Battery: 6 단계, 이미지 3개 중 3개
      • Gently pull out the two halves of Vector's head from between his arms.
      댓글 쓰기
    2. Anki Vector  Battery Replacement: 7 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 7 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the Anki Vector's belts on both sides of its body by gently sliding them off.
      • You should be able to pull them off without much effort.
      댓글 쓰기
    3. Anki Vector  Battery Replacement: 8 단계, 이미지 2개 중 1개 Anki Vector  Battery Replacement: 8 단계, 이미지 2개 중 2개
      • Pull off the covers attached to Vector's rear wheels.
      댓글 쓰기
    4. Anki Vector  Battery Replacement: 9 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 9 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 9 단계, 이미지 3개 중 3개
      • Unscrew the 2 mm screws located under the wheel covers using a Phillips #0 screwdriver.
      • Remove the rear wheel.
      댓글 쓰기
    5. Anki Vector  Battery Replacement: 10 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 10 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 10 단계, 이미지 3개 중 3개
      • Unscrew the two 2 mm body screws using a Phillips #0 screwdriver.
      댓글 쓰기
    6. Anki Vector  Battery Replacement: 11 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 11 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 11 단계, 이미지 3개 중 3개
      • Using two fingers gently pull off the lower rear panel.
      • Using your fingers, unplug the ribbon connector.
      댓글 쓰기
    7. Anki Vector  Battery Replacement: 12 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 12 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 12 단계, 이미지 3개 중 3개
      • Unscrew the two screws behind vector's neck.
      • Remove the capacitive touch assembly.
      댓글 쓰기
    8. Anki Vector  Battery Replacement: 13 단계, 이미지 2개 중 1개 Anki Vector  Battery Replacement: 13 단계, 이미지 2개 중 2개
      • With a moderate amount of force pull one of vector's top arms away from his body until it disconnects from the shaft.
      댓글 쓰기
    9. Anki Vector  Battery Replacement: 14 단계, 이미지 2개 중 1개 Anki Vector  Battery Replacement: 14 단계, 이미지 2개 중 2개
      • Gripping the shaft with needle nosed pliers, pull the opposite top arm off the main shaft.
      댓글 쓰기
    10. Anki Vector  Battery Replacement: 15 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 15 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 15 단계, 이미지 3개 중 3개
      • Pinch one end of the arm shaft and push it into the body.
      • Grab the other end and pull the shaft out of the body.
      댓글 쓰기
    11. Anki Vector  Battery Replacement: 16 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 16 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 16 단계, 이미지 3개 중 3개
      • Raise vectors arms all the way up and gently pull each arm out of its socket.
      댓글 쓰기
    12. Anki Vector  Battery Replacement: 17 단계, 이미지 2개 중 1개 Anki Vector  Battery Replacement: 17 단계, 이미지 2개 중 2개
      • Pull the wheel covers off of Vectors forward wheels.
      댓글 쓰기
    13. Anki Vector  Battery Replacement: 18 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 18 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 18 단계, 이미지 3개 중 3개
      • Using the same Phillips #0 screwdriver, unscrew the 2 mm screw under the wheel cover.
      • Gently pull the wheel off.
      댓글 쓰기
    14. Anki Vector  Battery Replacement: 19 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 19 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 19 단계, 이미지 3개 중 3개
      • Unscrew the two body screws located behind the front wheels.
      • Gently pull the cover from Vector's body
      • Be careful when removing the cover. The infrared sensor connects the cover to the body by wires.
      댓글 쓰기
    15. Anki Vector  Battery Replacement: 20 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 20 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 20 단계, 이미지 3개 중 3개
      • Gently unplug and remove the infrared sensor.
      댓글 쓰기
    16. Anki Vector  Battery Replacement: 21 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 21 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 21 단계, 이미지 3개 중 3개
      • Insert your Phillips #0 bit into a 4 mm nut driver and insert both into your bit driver.
      • Unscrew the three body screws.
      댓글 쓰기
    17. Anki Vector  Battery Replacement: 22 단계, 이미지 2개 중 1개 Anki Vector  Battery Replacement: 22 단계, 이미지 2개 중 2개
      • Gradually increasing applied force, pull the body apart.
      댓글 쓰기
    18. Anki Vector  Battery Replacement: 23 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 23 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 23 단계, 이미지 3개 중 3개
      • Remove the shoulder panel.
      • Remove the weight.
      댓글 쓰기
    19. Anki Vector  Battery Replacement: 24 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 24 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 24 단계, 이미지 3개 중 3개
      • Unplug the two motor connectors from the motherboard.
      댓글 쓰기
    20. Anki Vector  Battery Replacement: 25 단계, 이미지 3개 중 1개 Anki Vector  Battery Replacement: 25 단계, 이미지 3개 중 2개 Anki Vector  Battery Replacement: 25 단계, 이미지 3개 중 3개
      • Wriggle the battery free from the motherboard.
      • Using a soldering iron, desolder the connections from the battery to the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 48명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Shay Takei
회원 가입일: 04/16/19
1,831 평판
안내서 5개를 작성함
Cal Poly, Team S2-G6, Maness Spring 2019 Cal Poly, Team S2-G6, Maness Spring 2019 회원
CPSU-MANESS-S19S2G6
4 회원들
안내서 10개를 작성함
25가이드 댓글
Ok nice step by step guide but what are the specs for the battery as they’re not visable in any of the pictures…
John Fitzgerald - 답글 공유
Part Number: Li-Ion Poly 500mAh #1578B
3.7V 500mAh
Brian - 답글 공유
Who manages to do all of this in 7 minutes ? Apparently it is a 3.7V battery, question is what is the max size that fits ? 3.5 x 2.5 x 0.4 cm is reported to fit, 4x3x0.5 might as well.
Holger Brueckner - 답글 공유
Any idea where to get one ?
Gordon Hamilton - 답글 공유
Who manages to do all of this is 7 minutes?
me
Kerigan Creighton - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 77
지난 30일: 425
전체 시간: 34,556
