주요 콘텐츠로 건너뛰기
Astro A20 Battery Replacement
Jasmine Yarbrough
Jasmine Yarbrough3 다른 기여자
최종 수정일 March 27, 2024
10 - 15 분
조정
If the Astro A20 will not turn on or the battery will not charge then you will need to replace the battery.
필요한 것
부품
도구
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
더보기...
  1. Astro A20 Battery Replacement, Cushion: 1 단계, 이미지 1개 중 1개
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Astro A20 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
    All of this is accurate, except the battery & motherboard Are on the charging port side, opposite mic side unlike picture. The right earphone is correct side.
    rebjr2880 - 답글
  3. Astro A20 Battery Replacement: 3 단계, 이미지 2개 중 1개 Astro A20 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the ear cushion from the headset.
  4. Astro A20 Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Place hand on the opposite side of the speaker.
  5. Astro A20 Battery Replacement: 5 단계, 이미지 2개 중 1개 Astro A20 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
  6. Astro A20 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Lift and remove the speaker from the headset.
  7. Astro A20 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  8. Astro A20 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the motherboard to expose the battery.
  9. Astro A20 Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the battery with a plastic spudger.
    Where did you manage to find a replacement battery?
    mpapendorf - 답글
    Where do I get the battery from can not find it on eBay only can find for the Astro a50 I need it for the Astro a20
    Michael s - 답글
    Hey, does anyone know where I can find that battery?
    Rayner Duramer - 답글
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jasmine Yarbrough
회원 가입일: 09/10/18
1,017 평판
안내서 5개를 작성함
댓글 2개
Does it work for Astro A20 2nd Gen too?
Charly - 답글
this guide is so wrong! 1st the battery is on the left side by the charging port (a20 2gen)
Miguel Garcia - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 42
지난 30일: 171
전체 시간: 17,833
