주요 콘텐츠로 건너뛰기
Astro A50 2016 Base Station Motherboard Replacement
Vincent Seguin
Vincent Seguin3 다른 기여자
최종 수정일 June 23, 2022
5 - 10 분
쉬움
The motherboard is the large circuit board in the base station that controls the charging and sending of audio to the headset. This guide will show you how to disassemble and remove the motherboard form the base station.
필요한 것
도구
더보기...
  1. Astro A50 2016 Base Station Motherboard Replacement, Base Station Motherboard: 1 단계, 이미지 1개 중 1개
    • Remove the four rubber feet from the bottom of the base station using the plastic opening tool.
  2. Astro A50 2016 Base Station Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the ten 6 mm screws using a T8 screwdriver.
  3. Astro A50 2016 Base Station Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Astro A50 2016 Base Station Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 6 mm screws using a T6 screwdriver.
    • Remove each metal plate by lodging the plastic opening tool underneath it and using your hands to lift the plate away from the device.
  4. Astro A50 2016 Base Station Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Astro A50 2016 Base Station Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use your hand to gently pull the green side plates away from the center of the device.
  5. Astro A50 2016 Base Station Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the six 6mm screws using a T6 screwdriver.
    Que tipo o que nombre tiene la placa madre ? Y la venden por separado?
    daniel montoya - 답글
  6. Astro A50 2016 Base Station Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Astro A50 2016 Base Station Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Astro A50 2016 Base Station Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Lift up the motherboard from the base station and pull it away from the device to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Vincent Seguin
회원 가입일: 10/02/17
382 평판
안내서 3개를 작성함
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G1
3 회원들
안내서 10개를 작성함
5가이드 댓글
my base station dont turen on, the front leds. any solution?
edgar jesus cortez cosio - 답글
my base station dont turns on the front leds, any solution?
having the same problem {with the front LEDs not turning on or it not being recognized by pc}what does the white button on the base station motherboard do?
Devin Danimals - 답글
Where can I purchase one of these motherboards?
he-g-man-aftermath - 답글
I need a new base board any ideas where I may purchase one
Paul Bishop - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 84
전체 시간: 9,387
