Astro A50 2016 Base Station Motherboard Replacement
The motherboard is the large circuit board in the base station that controls the charging and sending of audio to the headset. This guide will show you how to disassemble and remove the motherboard form the base station.
Remove the four rubber feet from the bottom of the base station using the plastic opening tool.
Remove the six 6mm screws using a T6 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 5개
my base station dont turen on, the front leds. any solution?
my base station dont turns on the front leds, any solution?
having the same problem {with the front LEDs not turning on or it not being recognized by pc}what does the white button on the base station motherboard do?
Where can I purchase one of these motherboards?
I need a new base board any ideas where I may purchase one
