주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Astro Pyle PTBL7C Battery Replacement
필요한 것
    1. Astro Pyle PTBL7C  Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use the spudger to open the device from the front edge of the screen. Gently slide it in and push it up to open.
      • It may emit a cracking sound at it opens; this is only the locks coming apart.
      댓글 쓰기
    2. Astro Pyle PTBL7C  Battery Replacement: 2 단계, 이미지 2개 중 1개 Astro Pyle PTBL7C  Battery Replacement: 2 단계, 이미지 2개 중 2개
      • The battery will appear as pictured. Separate the back case from the device. Avoid damaging the wire that connects the speakers between the two halves of the case.
      댓글 쓰기
    3. Astro Pyle PTBL7C  Battery Replacement: 3 단계, 이미지 1개 중 1개
      • The battery is attached in two different ways; one wire is attached to the screen to support the screen's background led lights. Carefully desolder the wire without damaging the part connecting the battery to the screen.
      댓글 쓰기
    4. Astro Pyle PTBL7C  Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Desolder the wires pictured. These feed energy from the battery into the motherboard.
      • Use caution to avoid damaging the motherboard or other critical pieces.
      댓글 쓰기
    5. 이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Use a plastic card to gently break the adhesive holding the battery to the metal screen plate. Remove the battery.
      • Though non-functional, the battery still contains dangerous chemicals. Handle it directly as little as possible.
      댓글 쓰기
      • Install the new battery and solder all the connections back in place.
      • Visit this guide for more information on soldering and desoldering: iFixit Soldering Guide
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Abdulelah
회원 가입일: 10/22/16
214 평판
안내서 2개를 작성함
IUPUI, Team 5-5, Wilson Fall 2016 IUPUI, Team 5-5, Wilson Fall 2016 회원
IUPUI-WILSON-F16S5G5
3 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 28
전체 시간: 615
