주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus CM1745 Hard Drive Replacement
필요한 것
  1. Asus CM1745 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 Asus CM1745 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
    • Remember to unplug the device before beginning disassembly, to make sure that no power is running through the device during repair. You could risk hurting yourself and/or damage sensitive components.
    댓글 쓰기
  2. Asus CM1745 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Asus CM1745 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two cables from the rear of the Hard Drive.
    • Unscrew the two screws attached to the Hard Drive with a Phillips #0 screwdriver.
    댓글 쓰기
  3. Asus CM1745 Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 Asus CM1745 Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 Asus CM1745 Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Flip the computer over and remove the sidepanel on that side.
    • Remove the Phillips #0 screw(s) attached to the Hard Drive on this side.
    • Once removed, slide the Hard Drive out the back. Remember the orientation that the Hard Drive was in.
    댓글 쓰기
  4. Asus CM1745 Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 Asus CM1745 Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 Asus CM1745 Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Take your replacement Hard Drive (Picture does not necessarily represent the exact Hard Drive) and place it in the same slot as the old one.
    • Replace the two screws on the front of the cage and the screw(s) on the back.
    • Replace the power and data cables on the back of the hard drive.
    댓글 쓰기
결론
If everything looks to be in the right place, you should be able to boot the computer and boot into the BIOS to check if the Hard Drive is recognized. You will have to install a new Windows installation if this Hard Drive was your only Hard Drive.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
TC Fowlar
회원 가입일: 10/30/19
896 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 22
지난 30일: 86
전체 시간: 4,490
