주요 콘텐츠로 건너뛰기
Asus EeeBook X205TA Motherboard Replacement
Shahir Makary
Shahir Makary5 다른 기여자
최종 수정일 October 7, 2019
20 - 25 분
조정
더 많은 이미지가 필요함
누락된 단계
This guide will help you replace your Asus EeeBook X205TA motherboard in case it is damaged, you want a faster RAM, better data transfers or better graphics. If disposing motherboard , please follow the laws and regulations for proper disposal.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Asus EeeBook X205TA Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Asus EeeBook X205TA Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Unscrew all 10 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Asus EeeBook X205TA Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew all seven screws around the outer edge of the motherboard using 2mm Phillips Screwdriver.
  4. Asus EeeBook X205TA Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Asus EeeBook X205TA Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Unplug the No-Fuss Ribbon battery, screen, and speakers from the motherboard.
    • Carefully remove the ZIF screen connector.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Shahir Makary
회원 가입일: 10/06/16
294 평판
안내서 1개를 작성함
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G2
3 회원들
안내서 10개를 작성함
3가이드 댓글
Very clear and precise instructions. Thanks
wdkandler - 답글
Here is a more detailed view of all the cables that have to be unplugged before the motherboard can be extracted: https://ibb.co/jcgwUQ
Also, be aware that, even after all screws and cables are removed, it will still require a little bit of force to remove the motherboard, due to the thermal adhesive on the CPU and GPU. Do not be afraid to pull the motherboard! As long as you followed the instructions and disconnected all the EIGHT cables and SEVEN screws, you are not going to damage anything, it’s just thermal tape!
Sebastian Swirski - 답글
I guess because if the spill damage, the motherboard stop my keyboard from working and the usual from
Tayler Grant - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 51
전체 시간: 7,140
