주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus ROG G20CB RAM Replacement
필요한 것
    1. Asus ROG G20CB  RAM Replacement, Fan: 1 단계, 이미지 2개 중 1개 Asus ROG G20CB  RAM Replacement, Fan: 1 단계, 이미지 2개 중 2개
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
      댓글 쓰기
    2. Asus ROG G20CB  RAM Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
      댓글 쓰기
    3. Asus ROG G20CB  RAM Replacement: 3 단계, 이미지 1개 중 1개
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
      댓글 쓰기
    4. Asus ROG G20CB  RAM Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
      댓글 쓰기
    5. Asus ROG G20CB  RAM Replacement: 5 단계, 이미지 1개 중 1개
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
      댓글 쓰기
    6. Asus ROG G20CB  RAM Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
      댓글 쓰기
    1. Asus ROG G20CB  RAM Replacement, CPU Cooler: 7 단계, 이미지 1개 중 1개
      • Remove the 4.6 mm Phillips screw that secures the optical drive.
      댓글 쓰기
    2. Asus ROG G20CB  RAM Replacement: 8 단계, 이미지 1개 중 1개
      • Push the optical drive out of the chassis.
      댓글 쓰기
    3. Asus ROG G20CB  RAM Replacement: 9 단계, 이미지 1개 중 1개
      • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
      • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
      댓글 쓰기
    4. Asus ROG G20CB  RAM Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
      • Lift the CPU cooler out of the system.
      • Be sure to apply fresh thermal paste before reinstalling a cooler.
      댓글 쓰기
    1. Asus ROG G20CB  RAM Replacement, RAM: 11 단계, 이미지 1개 중 1개
      • Gently push outward on the two retaining clips on either side of the RAM stick.
      댓글 쓰기
    2. Asus ROG G20CB  RAM Replacement: 12 단계, 이미지 1개 중 1개
      • The RAM module should pop up at an angle.
      • Pull the RAM stick out carefully by grasping it by the edges.
      • Avoid touching gold contacts.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kimber-Starr
회원 가입일: 03/21/25
361 평판
안내서 3개를 작성함
UMass Dartmouth, Team 3-3, Botvin Spring 2025 UMass Dartmouth, Team 3-3, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S3G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 52
전체 시간: 673
