주요 콘텐츠로 건너뛰기
Asus ROG G752V Battery Replacement
필요한 것
  1. Asus ROG G752V Battery Replacement, Battery: 1 단계, 이미지 1/2 Asus ROG G752V Battery Replacement, Battery: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Make sure you disconnect the charger before starting this guide.
    • Pick out all 11 rubber plugs off of the back cover with a pair of tweezers.
  2. Asus ROG G752V Battery Replacement: 2 단계, 이미지 1/2 Asus ROG G752V Battery Replacement: 2 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, unscrew all twelve 5.2 mm screws on the back of the laptop.
    • There is one 5.2 mm screw under the rubber plug in the middle.
  3. Asus ROG G752V Battery Replacement: 3 단계, 이미지 1/1
    • Pull up the rubber seal and the service cover will come off.
  4. Asus ROG G752V Battery Replacement: 4 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
  5. Asus ROG G752V Battery Replacement: 5 단계, 이미지 1/1
    • Using your hands, pull the optical drive out.
  6. Asus ROG G752V Battery Replacement: 6 단계, 이미지 1/2 Asus ROG G752V Battery Replacement: 6 단계, 이미지 2/2
    • Use the iFixit Opening Tool to pry apart the back panel from the main body of the laptop.
    • Start from the front side of the laptop and then continue to the side for easier access.
  7. Asus ROG G752V Battery Replacement: 7 단계, 이미지 1/2 Asus ROG G752V Battery Replacement: 7 단계, 이미지 2/2
    • Remove the hinge on the back of the laptop cover using the iFixit Opening Tool. The piece should pop off.
    • Be gentle with the cover because there is a speaker wire attached to it.
  8. Asus ROG G752V Battery Replacement: 8 단계, 이미지 1/2 Asus ROG G752V Battery Replacement: 8 단계, 이미지 2/2
    • Disconnect the speaker wire.
  9. Asus ROG G752V Battery Replacement: 9 단계, 이미지 1/2 Asus ROG G752V Battery Replacement: 9 단계, 이미지 2/2
    • Slowly pull out the keyboard while lifting it about an inch.
    • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
  10. Asus ROG G752V Battery Replacement: 10 단계, 이미지 1/3 Asus ROG G752V Battery Replacement: 10 단계, 이미지 2/3 Asus ROG G752V Battery Replacement: 10 단계, 이미지 3/3
    • Using an ESD safe tool, detach all 3 ribbon cables securing the keyboard to the laptop.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
  11. Asus ROG G752V Battery Replacement: 11 단계, 이미지 1/2 Asus ROG G752V Battery Replacement: 11 단계, 이미지 2/2
    • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
    • Make sure that the screen is open like the photo. This will ensure that none your laptop components will not be bent.
  12. Asus ROG G752V Battery Replacement: 12 단계, 이미지 1/3 Asus ROG G752V Battery Replacement: 12 단계, 이미지 2/3 Asus ROG G752V Battery Replacement: 12 단계, 이미지 3/3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the left of the socket.
    • Pull parallel to the motherboard, not straight up.
  13. Asus ROG G752V Battery Replacement: 13 단계, 이미지 1/3 Asus ROG G752V Battery Replacement: 13 단계, 이미지 2/3 Asus ROG G752V Battery Replacement: 13 단계, 이미지 3/3
    • Remove two 5.8 mm screws holding the screen and the laptop located at the hinge.
    • This will unlatch the screen from the laptop entirely.
    • Remove the screen.
  14. Asus ROG G752V Battery Replacement: 14 단계, 이미지 1/1
    • Remove the four 5.8 mm screws securing the battery to the laptop.
  15. Asus ROG G752V Battery Replacement: 15 단계, 이미지 1/1
    • Use your hands to remove the battery.
    • If you're having trouble, push down on the black plastic on the screen side of the battery. This should release the battery.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 12명이 해당 안내서를 완성하였습니다.
Jeong
회원 가입일: 09/16/19
1,152 평판
안내서 5개 작성하였습니다
댓글 10개
There is 2 connection. What is the smaller connection for? Thanks.
Micky Max - 답글
The second set of wires going to the battery (shown on the right side between the tech's thumb and forefinger in the picture at the step where you remove the battery) are attached to a strip glued to the back of the battery. I believe it is a temperature sensor of some kind. Carefully peel it off the old battery, being careful not to bend it and press it to onto the new battery. There are two holes in the sensor strip, on at the right in the corner, another at the left end in the center. On the battery, there are two very small, hard to see alignment points to fit into those holes.
I see where Rich C says it's part of an LED strip. I didn't look at it closely.
Greg S. -
God, alot of people looked at my team’s project. Sorry it’s a piece of crap.
I had to do it for my tech writing class, got a solid B on it.
Jeong - 답글
Thanks for this write up, excellent job. As Mickey mentioned, there is a second connection, from the side of the existing battery. This is actually part of an LED strip that is secured to the battery with an adhesive strip. Some models have this glowing back panel. I used a filet knife to pop the LED panel off the old battery and then tack it on the new one.
Rich C - 답글
My lap top bears no relation to this but it is a UK spec laptop so may differ. I will need to purchase a kit from iFixit before I embark on replacing the battery in my laptop
Gerald Talbot - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 46
30일 전: 213
전체 시간: 21,623
