주요 콘텐츠로 건너뛰기
Asus X550ZA-SA100603E Hard Drive Replacement
Paul Flynn
Paul Flynn8 다른 기여자
최종 수정일 December 29, 2022
10 - 15 분
조정
This guide will walk you through a hard drive replacement in the Asus X550ZA-SA100603E which can upgrade computer speed and reduce mechanical failures.
Hard drives can fail over time due to heat, physical damage, humidity, dust, power surges, or from age and may need to be replaced every 7-10 years. Replacement may be required if the current drive has expired or has experienced hardware failure. Replacement can also be performed to increase computer speed and capacity.
Check the user manual to ensure the replacement drive is compatible. The user manual can be found at the ASUS website.
Remember to back up any important data from the old hard drive before removal.
No special skills are required to perform this repair.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
더보기...
  1. Asus X550ZA-SA100603E Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Remove all of the 10 bottom case screws.
    • Seven of them are 14 mm screws.
    • Three of them are 4 mm screws.
  2. Asus X550ZA-SA100603E Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • After the screws are removed, gently turn the computer to its upright position and open up the computer flap.
    • It is important to do this gently, as these pieces are loose.
  3. Asus X550ZA-SA100603E Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Pry open a gap between the keyboard and the lower piece using a spudger.
    • This will uncover all of the internals in the laptop itself.
  4. Asus X550ZA-SA100603E Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the hard drive out of its position to allow room for the new one.
    • Make certain the area is clean and no debris got into the slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Paul Flynn
회원 가입일: 01/14/19
16 평판
안내서 2개를 작성함
IUPUI, Team S5-G5, Wilson Spring 2019 IUPUI, Team S5-G5, Wilson Spring 2019 회원
IUPUI-WILSON-S19S5G5
3 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 458
