주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Audio-Technica ATH-M40x Left Driver Replacement
필요한 것
    1. Audio-Technica ATH-M40x Left Driver Replacement, Left Speaker: 1 단계, 이미지 3개 중 1개 Audio-Technica ATH-M40x Left Driver Replacement, Left Speaker: 1 단계, 이미지 3개 중 2개 Audio-Technica ATH-M40x Left Driver Replacement, Left Speaker: 1 단계, 이미지 3개 중 3개
      • Grip the ear cup, gently twist it, and pull it off.
      • Use a Phillips #0 screwdriver to remove the four 3 mm screws securing the driver.
      댓글 쓰기
    2. Audio-Technica ATH-M40x Left Driver Replacement: 2 단계, 이미지 3개 중 1개 Audio-Technica ATH-M40x Left Driver Replacement: 2 단계, 이미지 3개 중 2개 Audio-Technica ATH-M40x Left Driver Replacement: 2 단계, 이미지 3개 중 3개
      • Use a spudger to pry the driver from the headphones but don't pull it or yank it off as it is connected by wire cables and could rip those out.
      • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the small circuit board in the housing.
      • You will be able to desolder the driver wires more easily once the board is removed.
      댓글 쓰기
    3. Audio-Technica ATH-M40x Left Driver Replacement: 3 단계, 이미지 2개 중 1개 Audio-Technica ATH-M40x Left Driver Replacement: 3 단계, 이미지 2개 중 2개
      • Desolder the two connections labeled L+ and LG to disconnect the left driver from the headphones.
      • Be careful when using the soldering iron as it is extremely hot and can burn you. Use safety gloves if possible and helping hands to hold the circuit board. Alternatively, tape the board to a solder-safe surface to make the process easier.
      • Although this guide demonstrates how to replace the left driver, the right speaker wires are soldered onto this board also. When replacing the right driver, desolder the connectors labeled RG and R+.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Ezequiel Flores
회원 가입일: 09/16/24
97 평판
안내서 1개를 작성함
CSU Los Angeles, Team 5-1, Kershman Fall 2024 CSU Los Angeles, Team 5-1, Kershman Fall 2024 회원
CSULA-KERSHMAN-F24S5G1
6 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 23
지난 30일: 125
전체 시간: 1,923
