주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Axess TA2513-10WT Camera Replacement
필요한 것
    1. Axess TA2513-10WT Camera Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
      댓글 쓰기
    2. Axess TA2513-10WT Camera Replacement: 2 단계, 이미지 3개 중 1개 Axess TA2513-10WT Camera Replacement: 2 단계, 이미지 3개 중 2개 Axess TA2513-10WT Camera Replacement: 2 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
      • Slide the plastic opening tool gently along the sides.
      • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
      댓글 쓰기
    3. Axess TA2513-10WT Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
      댓글 쓰기
    4. Axess TA2513-10WT Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
      댓글 쓰기
    1. Axess TA2513-10WT Camera Replacement, Camera: 5 단계, 이미지 1개 중 1개
      • Turn the tablet over. Locate the left screw.
      • Use the magnetic screwdriver to remove the left screw.
      댓글 쓰기
    2. Axess TA2513-10WT Camera Replacement: 6 단계, 이미지 1개 중 1개
      • There is a bottom screw located to the right of the left screw that was just removed.
      • Remove the bottom screw using the magnetic screwdriver.
      댓글 쓰기
    3. Axess TA2513-10WT Camera Replacement: 7 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove the entire plastic cover using either tweezers or your fingers.
      댓글 쓰기
    4. Axess TA2513-10WT Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Brush the surfaces of the cameras to remove any debris that is present.
      댓글 쓰기
    5. Axess TA2513-10WT Camera Replacement: 9 단계, 이미지 1개 중 1개
      • There is a black plastic cover on the back of the tablet. It is attached to the ribbon cable.
      • Use tweezers to rotate the black plastic cover 90 degrees upwards.
      • Flip the cover up and pull out the ribbon cable.
      댓글 쓰기
    6. Axess TA2513-10WT Camera Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the ribbon cable from the port.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Steven Kavanagh
회원 가입일: 03/24/15
301 평판
안내서 3개를 작성함
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 회원
BU-SHAVER-S15S6G3
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 29
전체 시간: 519
