주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Azpen A720 Battery Replacement
필요한 것
  1. Azpen A720 Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Azpen A720 Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Battery Replacement: 2 단계, 이미지 3개 중 1개 Azpen A720 Battery Replacement: 2 단계, 이미지 3개 중 2개 Azpen A720 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the rear casing.
  4. Azpen A720 Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Locate the batteries' connection points.
  5. Azpen A720 Battery Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • A soldering iron can reach 600˚ F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
    • Use a soldering iron to melt the connections which attach the battery to the motherboard.
    • Disconnect the red and black wires from the motherboard.
  6. Azpen A720 Battery Replacement: 6 단계, 이미지 2개 중 1개 Azpen A720 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Peel the black sticker off the battery to disconnect the wifi antennae.
  7. Azpen A720 Battery Replacement: 7 단계, 이미지 3개 중 1개 Azpen A720 Battery Replacement: 7 단계, 이미지 3개 중 2개 Azpen A720 Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
    • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
  8. Azpen A720 Battery Replacement: 8 단계, 이미지 2개 중 1개 Azpen A720 Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the old battery and replace it with the new battery.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ben
회원 가입일: 03/18/15
280 평판
안내서 2개를 작성함
Michigan Tech, Team 1-3, Lauer Spring 2015 Michigan Tech, Team 1-3, Lauer Spring 2015 회원
MTU-LAUER-S15S1G3
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 24
전체 시간: 2,508
