주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Azpen A740 Camera Replacement
필요한 것
    1. Azpen A740 Camera Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
      댓글 쓰기
    1. Azpen A740 Camera Replacement, Camera: 2 단계, 이미지 1개 중 1개
      • You should see the motherboard, the speaker, and the battery.
      • The camera is surrounded by the red square.
      댓글 쓰기
    2. Azpen A740 Camera Replacement: 3 단계, 이미지 1개 중 1개
      • The camera is located at the top of the device and is attached by one screw with 3.75mm which is inside of the red circle. And one clip which is inside of the orange rectangle.
      • First remove the screw from the plastic connecting the camera to the motherboard.
      • The ZIF connector attaching the camera to the motherboard.
      댓글 쓰기
    3. Azpen A740 Camera Replacement: 4 단계, 이미지 1개 중 1개
      • With the plastic now removed from the camera, the user is able to unclip the camera from the motherboard by pulling up the black clip and sliding out the camera.
      • Here you can see the rear camera is on the top and the front camera is on the top. As you can see, it is not possible to replace one camera and not the other.
      댓글 쓰기
    4. Azpen A740 Camera Replacement: 5 단계, 이미지 1개 중 1개
      • This is what the camera looks like once completely removed from the tablet.
      • This is where the camera was previously, it is the place where the new camera must be placed.
      댓글 쓰기
    5. Azpen A740 Camera Replacement: 6 단계, 이미지 1개 중 1개
      • Now you are able to insert the new camera.
      • To reassemble your device, follow these instructions in reverse order.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Victoria Poitier
회원 가입일: 01/21/15
101 평판
안내서 1개를 작성함
USF Tampa, Team 4-5, Brown Winter 2015 USF Tampa, Team 4-5, Brown Winter 2015 회원
USFT-BROWN-W15S4G5
3 회원들
안내서 72개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 455
