주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Studio3 Wireless Hinge Replacement
필요한 것
    1. Beats Studio3 Wireless Hinge Replacement, Ear Pad: 1 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Hinge Replacement, Ear Pad: 1 단계, 이미지 2개 중 2개
      • Find the separation between the headset and ear cushion.
      • Use an opening tool to go underneath the separation site and split the pieces apart.
      댓글 쓰기
    2. Beats Studio3 Wireless Hinge Replacement: 2 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Hinge Replacement: 2 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Hinge Replacement: 2 단계, 이미지 3개 중 3개
      • You can also use your hands to remove it completely.
      • Pulling it off can be challenging; make sure to apply enough pressure.
      댓글 쓰기
    1. Beats Studio3 Wireless Hinge Replacement, Left Driver Assembly: 3 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Hinge Replacement, Left Driver Assembly: 3 단계, 이미지 2개 중 2개
      • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
      • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
      • Open the speaker by pulling the top layer of the speaker.
      댓글 쓰기
    2. Beats Studio3 Wireless Hinge Replacement: 4 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Hinge Replacement: 4 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Hinge Replacement: 4 단계, 이미지 3개 중 3개
      • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
      • Use a nylon spudger to remove the glue.
      • Pull on the wire to remove it while also removing the blue rubber band.
      댓글 쓰기
    3. Beats Studio3 Wireless Hinge Replacement: 5 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Hinge Replacement: 5 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Hinge Replacement: 5 단계, 이미지 3개 중 3개
      • Using a soldering iron to remove the cables on the charger port.
      • For help with soldering, check out the How to Solder and Desolder Connections guide.
      • Remove the two wires connected in the middle of the speaker using a soldering iron.
      • Remove the speaker from the headset.
      댓글 쓰기
    1. Beats Studio3 Wireless Hinge Replacement, Battery: 6 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Hinge Replacement, Battery: 6 단계, 이미지 2개 중 2개
      • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
      • Be gentle while removing this piece as it is glued on with adhesive.
      댓글 쓰기
    2. Beats Studio3 Wireless Hinge Replacement: 7 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Hinge Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
      댓글 쓰기
    3. Beats Studio3 Wireless Hinge Replacement: 8 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Hinge Replacement: 8 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Hinge Replacement: 8 단계, 이미지 3개 중 3개
      • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
      • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
      • The panel will pop open after separating.
      댓글 쓰기
    4. Beats Studio3 Wireless Hinge Replacement: 9 단계, 이미지 1개 중 1개
      • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
      • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
      댓글 쓰기
    5. Beats Studio3 Wireless Hinge Replacement: 10 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Hinge Replacement: 10 단계, 이미지 2개 중 2개
      • Use a nylon spudger to lift up the glue sticking the wires down.
      • Use a nylon spudger to lift the connector to disconnect the battery.
      댓글 쓰기
    1. Beats Studio3 Wireless Hinge Replacement, Hinge: 11 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Hinge Replacement, Hinge: 11 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Hinge Replacement, Hinge: 11 단계, 이미지 3개 중 3개
      • Pull the wire making sure that the blue rubber band is off.
      • Heat the glue holding the wires down with a hair dryer or heat gun until the glue softens.
      • Make sure not to overheat any device part, which could cause damage to the sound.
      • With a pointed nylon spudger, remove the glue.
      댓글 쓰기
    2. Beats Studio3 Wireless Hinge Replacement: 12 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Hinge Replacement: 12 단계, 이미지 2개 중 2개
      댓글 쓰기
    3. Beats Studio3 Wireless Hinge Replacement: 13 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Hinge Replacement: 13 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Hinge Replacement: 13 단계, 이미지 3개 중 3개
      • With a hair dryer or heating gun, heat the glue that is sticking the wires down.
      • Use a nylon spudger to remove the softened glue.
      • Remove the circular tape inside of the ear pad.
      댓글 쓰기
    4. Beats Studio3 Wireless Hinge Replacement: 14 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Hinge Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the single 3.5 mm screw with a Phillips #0 screwdriver.
      • Pull apart the top layer of the earpiece.
      댓글 쓰기
    5. Beats Studio3 Wireless Hinge Replacement: 15 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Hinge Replacement: 15 단계, 이미지 2개 중 2개
      • Remove the tape holding the wires in place.
      • Pull the wires through the hole with your hand.
      댓글 쓰기
    6. Beats Studio3 Wireless Hinge Replacement: 16 단계, 이미지 1개 중 1개
      • Bend the hinge and remove the two 3.5 mm screws with a Phillips #0 screwdriver.
      댓글 쓰기
    7. Beats Studio3 Wireless Hinge Replacement: 17 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Hinge Replacement: 17 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Hinge Replacement: 17 단계, 이미지 3개 중 3개
      • Pull the hinge down.
      • Pull on the wires one at a time making sure you don't damage them.
      댓글 쓰기
    8. Beats Studio3 Wireless Hinge Replacement: 18 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Hinge Replacement: 18 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • With tweezers, remove the pin located inside of the hinge.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nayeli watts
회원 가입일: 03/16/23
543 평판
안내서 3개를 작성함
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G4
3 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 47
지난 30일: 231
전체 시간: 10,969
