주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Studio3 Wireless Left Driver Assembly Replacement
필요한 것
    1. Beats Studio3 Wireless Left Driver Assembly Replacement, Ear Pad: 1 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Left Driver Assembly Replacement, Ear Pad: 1 단계, 이미지 2개 중 2개
      • Find the separation between the headset and ear cushion.
      • Use an opening tool to go underneath the separation site and split the pieces apart.
      댓글 쓰기
    2. Beats Studio3 Wireless Left Driver Assembly Replacement: 2 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Left Driver Assembly Replacement: 2 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Left Driver Assembly Replacement: 2 단계, 이미지 3개 중 3개
      • You can also use your hands to remove it completely.
      • Pulling it off can be challenging; make sure to apply enough pressure.
      댓글 쓰기
    1. Beats Studio3 Wireless Left Driver Assembly Replacement, Left Driver Assembly: 3 단계, 이미지 2개 중 1개 Beats Studio3 Wireless Left Driver Assembly Replacement, Left Driver Assembly: 3 단계, 이미지 2개 중 2개
      • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
      • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
      • Open the speaker by pulling the top layer of the speaker.
      댓글 쓰기
    2. Beats Studio3 Wireless Left Driver Assembly Replacement: 4 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Left Driver Assembly Replacement: 4 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Left Driver Assembly Replacement: 4 단계, 이미지 3개 중 3개
      • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
      • Use a nylon spudger to remove the glue.
      • Pull on the wire to remove it while also removing the blue rubber band.
      댓글 쓰기
    3. Beats Studio3 Wireless Left Driver Assembly Replacement: 5 단계, 이미지 3개 중 1개 Beats Studio3 Wireless Left Driver Assembly Replacement: 5 단계, 이미지 3개 중 2개 Beats Studio3 Wireless Left Driver Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Using a soldering iron to remove the cables on the charger port.
      • For help with soldering, check out the How to Solder and Desolder Connections guide.
      • Remove the two wires connected in the middle of the speaker using a soldering iron.
      • Remove the speaker from the headset.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nayeli watts
회원 가입일: 03/16/23
543 평판
안내서 3개를 작성함
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G4
3 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 91
전체 시간: 2,930
