주요 콘텐츠로 건너뛰기
Bissell Air180 Fan Replacement
Aleah Ramos
Aleah Ramos2 다른 기여자
최종 수정일 December 19, 2022
8 분
조정
The fan on the Bissell Air180 is a vital component in air purification. With propellers constantly in motion, it can be easy for something to get stuck or cause this component to malfunction.
필요한 것
도구
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Bissell Air180 Fan Replacement, Air Filter: 1 단계, 이미지 2개 중 1개 Bissell Air180 Fan Replacement, Air Filter: 1 단계, 이미지 2개 중 2개
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Fan Replacement, Power Supply: 4 단계, 이미지 1개 중 1개
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Fan Replacement: 5 단계, 이미지 3개 중 1개 Bissell Air180 Fan Replacement: 5 단계, 이미지 3개 중 2개 Bissell Air180 Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
  6. Bissell Air180 Fan Replacement, Control Buttons: 6 단계, 이미지 3개 중 1개 Bissell Air180 Fan Replacement, Control Buttons: 6 단계, 이미지 3개 중 2개 Bissell Air180 Fan Replacement, Control Buttons: 6 단계, 이미지 3개 중 3개
    • Pry off the top vent, separating it from the fan and motherboard housing.
  7. Bissell Air180 Fan Replacement: 7 단계, 이미지 2개 중 1개 Bissell Air180 Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Pry the button control panel up and away from the rest of the device using a spudger.
  8. Bissell Air180 Fan Replacement: 8 단계, 이미지 2개 중 1개 Bissell Air180 Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the wire connecting the button controls to the fan housing to fully disconnect the button controls from the device.
  9. Bissell Air180 Fan Replacement, Fan: 9 단계, 이미지 3개 중 1개 Bissell Air180 Fan Replacement, Fan: 9 단계, 이미지 3개 중 2개 Bissell Air180 Fan Replacement, Fan: 9 단계, 이미지 3개 중 3개
    • Flip the motherboard and fan housing upside down to find where to disconnect the fan from the rest of the device.
    • Remove the two 11 mm screws using a Phillips #1 screwdriver.
    • Detach the two wires connecting the fan to the motherboard so the fan is now loose inside the housing.
  10. Bissell Air180 Fan Replacement: 10 단계, 이미지 2개 중 1개 Bissell Air180 Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Flip the motherboard and fan housing back over and pull the fan up separating it from the rest of the device.
결론
작성자
2다른 기여자 명과 함께
Aleah Ramos
회원 가입일: 10/26/22
533 평판
안내서 5개를 작성함
UMass Dartmouth, Team 3-4, Botvin Fall 2022 UMass Dartmouth, Team 3-4, Botvin Fall 2022 회원
UMASSD-BOTVIN-F22S3G4
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 4
전체 시간: 237
