주요 콘텐츠로 건너뛰기
Bissell Air180 Power Supply Replacement
Aleah Ramos
Aleah Ramos2 다른 기여자
최종 수정일 December 19, 2022
5 분
조정
The power supply on the Bissell Air180 is the housing on the bottom half of the device housing the air filter. Through this housing, the power cord that is plugged into the wall sends power through the device. Removing the power supply will allow you to replace the entire power supply housing or replace the power cord.
필요한 것
도구
  1. Bissell Air180 Power Supply Replacement, Air Filter: 1 단계, 이미지 2개 중 1개 Bissell Air180 Power Supply Replacement, Air Filter: 1 단계, 이미지 2개 중 2개
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Power Supply Replacement: 2 단계, 이미지 1개 중 1개
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Power Supply Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Power Supply Replacement, Power Supply: 4 단계, 이미지 1개 중 1개
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Power Supply Replacement: 5 단계, 이미지 3개 중 1개 Bissell Air180 Power Supply Replacement: 5 단계, 이미지 3개 중 2개 Bissell Air180 Power Supply Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
결론
작성자
2다른 기여자 명과 함께
Aleah Ramos
회원 가입일: 10/26/22
533 평판
안내서 5개를 작성함
UMass Dartmouth, Team 3-4, Botvin Fall 2022 UMass Dartmouth, Team 3-4, Botvin Fall 2022 회원
UMASSD-BOTVIN-F22S3G4
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 119
