주요 콘텐츠로 건너뛰기
Blackview BV9800 Pro Screen Replacement
필요한 것
  1. Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: 1 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: 1 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: 1 단계, 이미지 3개 중 3개
    • Flip the phone over.
    • Remove the four T5 screws.
    • Remove the single T5 screw from the bottom, next to the charging port.
  2. Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: 2 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: 2 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: 2 단계, 이미지 3개 중 3개
    • Remove the screws from the sides.
    • Remove the screws holding the camera frame.
  3. Blackview BV9800 Pro Screen Replacement, Removing side bezels: 3 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Removing side bezels: 3 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Removing side bezels: 3 단계, 이미지 3개 중 3개
    • Pry out the sim car holder
    • It has a dual sim card holder, but to remove the second tray you need a pin or an iphone sim card opener to push it out.
    • Use a spudger or a utility knife to pry off the side bezels.
  4. Blackview BV9800 Pro Screen Replacement, Separate the back cover: 4 단계, 이미지 2개 중 1개 Blackview BV9800 Pro Screen Replacement, Separate the back cover: 4 단계, 이미지 2개 중 2개
    • Pry in one corner and separate the back.
  5. Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: 5 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: 5 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: 5 단계, 이미지 3개 중 3개
    • Use a plastic spudger to disconnect the flex connectors.
  6. Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: 6 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: 6 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: 6 단계, 이미지 3개 중 3개
    • Use a plastic spudger to disconnect the flex connector and the antenna
  7. Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: 7 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: 7 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Heat up this PCB with either iOpener or a heat gun on low temp (100-120 Celsius) to loosen the adhesive and pry it off from the side.
    • Remove the screws.
    • The last screw is under a tamper-proof sticker
    • Use plastic spudger or tweezers to disconnect the camera flex cable from the top
    • Gently lift up the plasctic cover from the right side. It is still connected to the board below!
    • Disconnect the flex cable
    • Disconnect the antenna
  8. Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: 8 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: 8 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: 8 단계, 이미지 3개 중 3개
    • Remove the screws from the battery cover
    • Carefully release the ribbon cable from the battery shield. It is stuck down at two points.
  9. Blackview BV9800 Pro Screen Replacement, Disconnect connectors: 9 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Disconnect connectors: 9 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Disconnect connectors: 9 단계, 이미지 3개 중 3개
    • Disconnect the flex connectors and remove the battery
  10. Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: 10 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: 10 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: 10 단계, 이미지 3개 중 3개
    • Remove two J000 screws
    • Carefully pry up the camera. Heat from the glass side if necessary.
    • Unscrew and remove the camera assembly
  11. Blackview BV9800 Pro Screen Replacement, Remove light sensor: 11 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Remove light sensor: 11 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Remove light sensor: 11 단계, 이미지 3개 중 3개
    • Heat the light sensor from both sides to loosen the adhesive and gently pry them out of their sockets
    • Using tweezers slowly and carefully lift out the light sensor
  12. Blackview BV9800 Pro Screen Replacement, Remove audio jack: 12 단계, 이미지 3개 중 1개 Blackview BV9800 Pro Screen Replacement, Remove audio jack: 12 단계, 이미지 3개 중 2개 Blackview BV9800 Pro Screen Replacement, Remove audio jack: 12 단계, 이미지 3개 중 3개
    • Use some isopropyl alcohol if necessary to loosen the glue further on the audio jack
    • Grab it with strong tweezers and wiggle from side to side and upwards until it comes out. Heat further if necessary.
    • Lift it out and transfer to the new screen.
  13. Blackview BV9800 Pro Screen Replacement, Remove ribbon cable and charging port: 13 단계, 이미지 2개 중 1개 Blackview BV9800 Pro Screen Replacement, Remove ribbon cable and charging port: 13 단계, 이미지 2개 중 2개
    • Gently peel the flex cable u p and transfer to the new assembly.
    • Heat it up if the adhesive is too strong.
    • Heat up and pry up the bottom PCB (charging port) and transfer to the new screen.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
honakrisi
회원 가입일: 01/28/20
3,718 평판
안내서 8개를 작성함
댓글 2개
You saved my mobile phone. Even I did not replace the screen, I just replace the battery. I forgot some connectors but your post remind me and the mobile back to work!
Colin Wen - 답글
I’m glad that you managed to save your device!
honakrisi -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 33
지난 30일: 100
전체 시간: 4,502
