주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blink Outdoor 4 Camera Replacement
필요한 것
  1. Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: 1 단계, 이미지 3개 중 1개 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: 1 단계, 이미지 3개 중 2개 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: 1 단계, 이미지 3개 중 3개
    • Remove the mounting bracket from the device if necessary.
    • Flip the camera upside down.
    • The word 'Blink' should be at the top.
    • Insert the swivel multi-tool that was included in the Blink Outdoor 4 box into the small notch located inside the silver circle in the center of the device.
    • Twist to the left until you hear a click.
    댓글 쓰기
  2. Blink Outdoor 4 Camera Replacement: 2 단계, 이미지 2개 중 1개 Blink Outdoor 4 Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry the back casing off the device.
    • Remove the two batteries and set them aside.
    • When reattaching the back casing, turn the swivel tool to the right.
    댓글 쓰기
  3. Blink Outdoor 4 Camera Replacement: 3 단계, 이미지 2개 중 1개 Blink Outdoor 4 Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Remove all four screws near the battery compartments using a Phillips #1 screwdriver.
    • Make sure to keep track of the screws for reassembly.
    댓글 쓰기
  4. Blink Outdoor 4 Camera Replacement: 4 단계, 이미지 3개 중 1개 Blink Outdoor 4 Camera Replacement: 4 단계, 이미지 3개 중 2개 Blink Outdoor 4 Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Turn the device on its side.
    • Use a plastic spudger to gently pry off the front cover of the device.
    댓글 쓰기
  5. Blink Outdoor 4 Camera Replacement: 5 단계, 이미지 3개 중 1개 Blink Outdoor 4 Camera Replacement: 5 단계, 이미지 3개 중 2개 Blink Outdoor 4 Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the two small black screws in the upper right corner of the board.
    • Make sure to keep the screws for reassembly.
    • Gently lift the motherboard out of the device by its edges.
    • Do not pull on the board because it's attached to some cables from underneath and it could damage the device.
    댓글 쓰기
  6. Blink Outdoor 4 Camera Replacement: 6 단계, 이미지 3개 중 1개 Blink Outdoor 4 Camera Replacement: 6 단계, 이미지 3개 중 2개 Blink Outdoor 4 Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Squeeze the edges of the white camera connector and slide it out of the socket on the motherboard.
    • If that doesn't work, use the point of a spudger to push on alternating sides of the white camera connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • Remove the camera from the device.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Delaney Hye
회원 가입일: 02/05/26
749 평판
안내서 5개를 작성함
Texas Tech, Team 11-5, Weston Spring 2026 Texas Tech, Team 11-5, Weston Spring 2026 회원
TTU-WESTON-S26S11G5
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 31
지난 30일: 127
전체 시간: 332
