주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blu Grand M2 Display Replacement
필요한 것
  1. Blu Grand M2 Display Replacement, Display: 1 단계, 이미지 2개 중 1개 Blu Grand M2 Display Replacement, Display: 1 단계, 이미지 2개 중 2개
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
    댓글 쓰기
  2. Blu Grand M2 Display Replacement: 2 단계, 이미지 1개 중 1개
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
    댓글 쓰기
  3. Blu Grand M2 Display Replacement: 3 단계, 이미지 3개 중 1개 Blu Grand M2 Display Replacement: 3 단계, 이미지 3개 중 2개 Blu Grand M2 Display Replacement: 3 단계, 이미지 3개 중 3개
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
    댓글 쓰기
  4. Blu Grand M2 Display Replacement: 4 단계, 이미지 2개 중 1개 Blu Grand M2 Display Replacement: 4 단계, 이미지 2개 중 2개
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
    댓글 쓰기
  5. Blu Grand M2 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
    댓글 쓰기
  6. Blu Grand M2 Display Replacement: 6 단계, 이미지 3개 중 1개 Blu Grand M2 Display Replacement: 6 단계, 이미지 3개 중 2개 Blu Grand M2 Display Replacement: 6 단계, 이미지 3개 중 3개
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Christopher
회원 가입일: 09/10/18
192 평판
안내서 1개를 작성함
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018 회원
GCC-LUSTER-F18S1G3
4 회원들
안내서 8개를 작성함
1가이드 댓글
What type of torx screwdriver did you use?
npyles86 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 37
전체 시간: 2,203
