주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Boosted Board 1st Generation Remote Battery Replacement
필요한 것
    1. Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: 1 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: 1 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: 1 단계, 이미지 3개 중 3개
      • Before disassembling your remote, be sure it is powered off.
      • Remove the four 17.57mm screws from the bottom of the case with a PH0 screwdriver.
      댓글 쓰기
    2. Boosted Board 1st Generation Remote Battery Replacement: 2 단계, 이미지 2개 중 1개 Boosted Board 1st Generation Remote Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Carefully separate the two halves of the casing by pulling them apart at the seam.
      • Be sure to keep the scroll wheel, lever and buttons attached to the housing.
      댓글 쓰기
    3. Boosted Board 1st Generation Remote Battery Replacement: 3 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Remote Battery Replacement: 3 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Remote Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the rectangular black adhesive foam on top of the battery by peeling it away from the battery.
      • Desolder the battery connections from the circuit board.
      • Replace the dead battery with a new 3.7 volt lithium polymer battery.
      • Refer here for more information how to desolder the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kevin Manko
회원 가입일: 10/06/16
164 평판
안내서 1개를 작성함
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G7
4 회원들
안내서 6개를 작성함
4가이드 댓글
Where can I get the battery? Or can you give specs? Thanks!
Dan Davie - 답글 공유
hi my name is Eugene.  I have a question .  My skateboard remote is gone.  remotes are not sold in my country.  what should i do how can i use the skateboard .  we sell remotes from another company.  how can it be adjusted to my boosted mini .  help me solve the issue please
Evgeny Bubnov - 답글 공유
You can't use 3rd party remotes with proprietary Boosted products.
Tom Tamaira - 답글 공유
Verified this works with V2 and V3 remotes as well. I did a R29 and it works great. Thank you for the info.
Thayne Christiansen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 69
전체 시간: 5,946
