주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose SoundLink Mini II Audio Port/USB Replacement
필요한 것
    1. Bose SoundLink Mini II Audio Port/USB Replacement, Battery: 1 단계, 이미지 2개 중 1개 Bose SoundLink Mini II Audio Port/USB Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Flip the speaker over onto its back.
      댓글 쓰기
    2. Bose SoundLink Mini II Audio Port/USB Replacement, Remove the rubber base: 2 단계, 이미지 2개 중 1개 Bose SoundLink Mini II Audio Port/USB Replacement, Remove the rubber base: 2 단계, 이미지 2개 중 2개
      • Gently remove the rubber base from speaker by pulling around the edges.
      댓글 쓰기
    3. Bose SoundLink Mini II Audio Port/USB Replacement: 3 단계, 이미지 2개 중 1개 Bose SoundLink Mini II Audio Port/USB Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the four 6mm T9 Torx bit screws from the corners of the battery.
      댓글 쓰기
    4. Bose SoundLink Mini II Audio Port/USB Replacement: 4 단계, 이미지 3개 중 1개 Bose SoundLink Mini II Audio Port/USB Replacement: 4 단계, 이미지 3개 중 2개 Bose SoundLink Mini II Audio Port/USB Replacement: 4 단계, 이미지 3개 중 3개
      • Carefully lift the battery from the side nearest the four gold contact pins, but don't try to fully remove it yet.
      • At this point, the battery remains connected via four wires to the power supply board.
      • Carefully desolder the four wires from the power supply board in order to completely detach the battery. There is very little room for the soldering iron without damaging the case or the board; you may want to remove the board first.
      • For help with soldering, see the soldering guide.
      • Alternatively, you may remove the battery and power supply board together, without any soldering, but access requires some additional disassembly while carefully leaving the battery connected via the wires the entire time.
      댓글 쓰기
    5. Bose SoundLink Mini II Audio Port/USB Replacement, Bose Technicians' Instruction Manual: 5 단계, 이미지 1개 중 1개
      댓글 쓰기
    1. Bose SoundLink Mini II Audio Port/USB Replacement, Audio Port/USB Circuit Board: 6 단계, 이미지 1개 중 1개
      • With the battery removed the button board will now be visible.
      댓글 쓰기
    2. Bose SoundLink Mini II Audio Port/USB Replacement: 7 단계, 이미지 3개 중 1개 Bose SoundLink Mini II Audio Port/USB Replacement: 7 단계, 이미지 3개 중 2개 Bose SoundLink Mini II Audio Port/USB Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the rear grille using the metal spudger.
      • The grille bends and deforms easily.
      댓글 쓰기
    3. Bose SoundLink Mini II Audio Port/USB Replacement: 8 단계, 이미지 3개 중 1개 Bose SoundLink Mini II Audio Port/USB Replacement: 8 단계, 이미지 3개 중 2개 Bose SoundLink Mini II Audio Port/USB Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the eight 9mm T9 Torx screws from the circuit board and back panel.
      • Use a metal spudger to release the ribbon cable connector and remove cable from the audio/USB board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Devon
회원 가입일: 02/15/17
545 평판
안내서 2개를 작성함
USF Tampa, Team 5-2, Passmore Spring 2017 USF Tampa, Team 5-2, Passmore Spring 2017 회원
USFT-PASSMORE-S17S5G2
4 회원들
안내서 31개를 작성함
1가이드 댓글
Where did you get the replacement part?
Viesturs Rauza - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 35
지난 30일: 176
전체 시간: 23,929
