주요 콘텐츠로 건너뛰기
Busch + Müller Toplight 2C permanent battery replacement
Fritz
Fritz2 다른 기여자
최종 수정일 November 7, 2023
2 시간
어려움
추천 가이드
커뮤니티-기여 안내서
The manufacturer told me by email that the device is not repairable. We are doing it anyway. The cost of a new better battery is about half the purchase value for a new lamp.
The housing has a waterproof ultrasonic weld. To open the housing, it must be sawed open or destroyed. Subsequently, it is glued back together so that it becomes watertight.
  1. Busch + Müller Toplight 2C permanent battery replacement, Sawing to open the housing: 1 단계, 이미지 2개 중 1개 Busch + Müller Toplight 2C permanent battery replacement, Sawing to open the housing: 1 단계, 이미지 2개 중 2개
    • Saw the lamp along the ultrasonic welding seam with a fine saw (e.g. Japanese saw).
    • A total of four straight cuts must be made
    • Saw carefully so that the electronics or the battery do not get damaged
  2. Busch + Müller Toplight 2C permanent battery replacement, Open housing: 2 단계, 이미지 3개 중 1개 Busch + Müller Toplight 2C permanent battery replacement, Open housing: 2 단계, 이미지 3개 중 2개 Busch + Müller Toplight 2C permanent battery replacement, Open housing: 2 단계, 이미지 3개 중 3개
    • The housing should fall apart into two halves after sawing
  3. Busch + Müller Toplight 2C permanent battery replacement, Remove battery: 3 단계, 이미지 2개 중 1개 Busch + Müller Toplight 2C permanent battery replacement, Remove battery: 3 단계, 이미지 2개 중 2개
    • Pull the old battery out of the socket
    • The plug may be relatively tight in the socket. Simply wiggle it until it can be pulled out or use pliers
  4. Busch + Müller Toplight 2C permanent battery replacement, Disassemble & recycle battery: 4 단계, 이미지 3개 중 1개 Busch + Müller Toplight 2C permanent battery replacement, Disassemble & recycle battery: 4 단계, 이미지 3개 중 2개 Busch + Müller Toplight 2C permanent battery replacement, Disassemble & recycle battery: 4 단계, 이미지 3개 중 3개
    • Under the black foil there are two Li-Io cells in AAA size.
    • At the two outer ends are the negative terminals, which are connected with a metal clip
    • Remove the round stickers and the long metal clip
    • Remove the cables including the socket
  5. Busch + Müller Toplight 2C permanent battery replacement, Prepare new batteries: 5 단계, 이미지 3개 중 1개 Busch + Müller Toplight 2C permanent battery replacement, Prepare new batteries: 5 단계, 이미지 3개 중 2개 Busch + Müller Toplight 2C permanent battery replacement, Prepare new batteries: 5 단계, 이미지 3개 중 3개
    • Buy 2x ICR10440 with solder tag
    • (The batteries used here are ICR10440; 3,7V each 320mAh with Z-solder tag)
    • Put the batteries with the positive side to each other and solder the lugs
    • Now solder the red connection cable
  6. Busch + Müller Toplight 2C permanent battery replacement, Soldering and packing new batteries together: 6 단계, 이미지 3개 중 1개 Busch + Müller Toplight 2C permanent battery replacement, Soldering and packing new batteries together: 6 단계, 이미지 3개 중 2개 Busch + Müller Toplight 2C permanent battery replacement, Soldering and packing new batteries together: 6 단계, 이미지 3개 중 3개
    • The outer solder lugs are soldered to the sheet metal (paper clip as soldering aid).
    • The black connection cable is also soldered to the sheet metal
    • Stick the yellow adhesive tape on the open contacts
    • Stick the circular red stickers on the outer positive terminals again
    • Fix the new battery pack with insulating tape.
  7. Busch + Müller Toplight 2C permanent battery replacement, Assembly / Mounting: 7 단계, 이미지 3개 중 1개 Busch + Müller Toplight 2C permanent battery replacement, Assembly / Mounting: 7 단계, 이미지 3개 중 2개 Busch + Müller Toplight 2C permanent battery replacement, Assembly / Mounting: 7 단계, 이미지 3개 중 3개
    • Plug the power connector into the socket of the board
    • Insert the board into the black housing with the USB socket pointing downwards
    • Put on the reflector
    • To make the housing watertight again, the previously sawed seam must be glued together with a gap-filling adhesive. This can be done for example with Sikaflex
  8. Busch + Müller Toplight 2C permanent battery replacement, Bonding the housing: 8 단계, 이미지 3개 중 1개 Busch + Müller Toplight 2C permanent battery replacement, Bonding the housing: 8 단계, 이미지 3개 중 2개 Busch + Müller Toplight 2C permanent battery replacement, Bonding the housing: 8 단계, 이미지 3개 중 3개
    • Apply glue carefully along the contour (e.g. Sikaflex)
    • Make sure that the LEDs and the switch remain clean.
    • Close the housing and let the glue harden.
  9. Busch + Müller Toplight 2C permanent battery replacement, Ready, function test: 9 단계, 이미지 3개 중 1개 Busch + Müller Toplight 2C permanent battery replacement, Ready, function test: 9 단계, 이미지 3개 중 2개 Busch + Müller Toplight 2C permanent battery replacement, Ready, function test: 9 단계, 이미지 3개 중 3개
    • Clip the lamp into the holder
결론
Work through the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Fritz
회원 가입일: 07/11/17
190 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 30
지난 30일: 84
전체 시간: 2,145
