주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
CAT S22 Flip Battery Replacement
필요한 것
  1. CAT S22 Flip Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unscrew the large screw on the back of the phone using a flathead screwdriver or coin.
    • The screw will always be completely unscrewed after 4 full counter-clockwise rotations.
    • The screw cannot be completely removed so that you can’t lose the screw.
    댓글 쓰기
  2. CAT S22 Flip Battery Replacement: 2 단계, 이미지 1개 중 1개
    • There is a slot on the upper left side of the back plate to insert the Spudger.
    • Use a spudger to pry up the back plate.
    댓글 쓰기
  3. CAT S22 Flip Battery Replacement: 3 단계, 이미지 1개 중 1개
    • There is a slot to insert a spudger at the bottom of the battery.
    • Use a spudger to lift the battery out of the phone.
    • Do not operate on a devise with a swollen battery. Do not dispose of a swollen battery into general waste systems. You can dispose of the batteries with a qualified technician or facility.
    댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Stephan Shaffer
회원 가입일: 09/25/25
234 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 23
지난 30일: 61
전체 시간: 277
