주요 콘텐츠로 건너뛰기
CHI Original Power Cord Replacement
Eric Knigga
Eric Knigga2 다른 기여자
최종 수정일 December 15, 2017
15 - 20 분
쉬움
This guide will show you the steps necessary for deconstruction and replacement of the CHI Original power cord.
필요한 것
도구
더보기...
  1. CHI Original Power Cord Replacement, Hinge Spring: 1 단계, 이미지 2개 중 1개 CHI Original Power Cord Replacement, Hinge Spring: 1 단계, 이미지 2개 중 2개
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Power Cord Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Power Cord Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the hinge pin.
  4. CHI Original Power Cord Replacement: 4 단계, 이미지 1개 중 1개
    • Separate the two halves of the CHI Original.
  5. CHI Original Power Cord Replacement: 5 단계, 이미지 2개 중 1개 CHI Original Power Cord Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Power Cord Replacement, Power Cord: 6 단계, 이미지 2개 중 1개 CHI Original Power Cord Replacement, Power Cord: 6 단계, 이미지 2개 중 2개
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Power Cord Replacement: 7 단계, 이미지 1개 중 1개
    • Gently pull upwards on the connection point and disconnect the power cord.
결론
작성자
2다른 기여자 명과 함께
Eric Knigga
회원 가입일: 08/23/17
224 평판
안내서 2개를 작성함
IUPUI, Team S1-G2, Freund Fall 2017 IUPUI, Team S1-G2, Freund Fall 2017 회원
IUPUI-FREUND-F17S1G2
4 회원들
안내서 3개를 작성함
댓글 5개
Do you know where to get a replacement power cord?
Taylor Bradford - 답글
How/where do you purchase the replacement cord?
fixitman - 답글
Where do you order an actual cord from??
Kelly Hickman - 답글
Where we can get Power Cord?
Nazim - 답글
Bonjour Nazim, j'ai trouvé le bon câble pour réparer le modèle GF1001EUN Farouk Systems USA sur le site web de pgservice :
Hi Nazim, I found the right cable to repair the GF1001EUN Farouk Systems USA model on the pgservice website :
https://pgservice.cc/fr/products/gammapi...
Sonny -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 44
전체 시간: 6,974
