주요 콘텐츠로 건너뛰기
CHI Spin N Curl Rotating Curler Directional Buttons Replacement
Annalise White
Annalise White3 다른 기여자
최종 수정일 July 5, 2023
30 분 - 1 시간
조정
누락된 단계
If your CHI Spin N Curl Rotating Curler(model CA2288A) is not spinning correctly or if the buttons keep getting stuck, use this guide to replace the directional buttons.
The buttons that are being replaced are supposed to spin the chamber when pressed, so that the hair is able to go inside of the chamber and be spun. If the buttons are stuck, the curler could bring no hair inside or could get stuck with your hair inside of the chamber.
Before using this guide, be sure to inspect the buttons for any debris around the buttons. You can use isopropyl alcohol on a cotton swab to clean any debris found.
Before beginning this repair, be sure that your curler is unplugged from the power source and it has cooled off if it has been used recently.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Power Cord: 1 단계, 이미지 1개 중 1개
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 3 단계, 이미지 2개 중 1개 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 4 단계, 이미지 2개 중 1개 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 5 단계, 이미지 3개 중 1개 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 5 단계, 이미지 3개 중 2개 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the screws holding the barrel in.
  7. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the screws using Phillips #00 screwdriver and take off the components.
    • Once all screws are removed, take out the barrel accessing the motherboard underneath.
  8. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Using metal spudger, lift and remove the motherboard and disconnect the top components.
  9. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Directional Buttons: 9 단계, 이미지 1개 중 1개
    • After the motherboard is removed, use the metal spudger to push and remove the directional buttons, and wipe underneath with a slightly damp alcohol cotton pad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Annalise White
회원 가입일: 10/26/22
530 평판
안내서 5개를 작성함
UMass Dartmouth, Team 2-7, Petersen Fall 2022 UMass Dartmouth, Team 2-7, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G7
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 638
