주요 콘텐츠로 건너뛰기
CHI Spin N Curl Rotating Curler Power Cord Replacement
Jacqueline Ramirez
Jacqueline Ramirez5 다른 기여자
최종 수정일 January 5, 2024
15 - 25 분
조정
The CHI Spin and Curl Rotating Curler should work efficiently when plugged in. If the device still does not work after changing batteries or checking the power source, the issue may lie within the power cord. This guide will demonstrate how to replace the damaged power cord and fix the device.
WARNING: electricity hazard. The individual repairing should be aware of the danger of working on this project while the electricity is running on the device.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. CHI Spin N Curl Rotating Curler Power Cord Replacement, Power Cord: 1 단계, 이미지 1개 중 1개
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Power Cord Replacement: 2 단계, 이미지 1개 중 1개
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Power Cord Replacement: 3 단계, 이미지 2개 중 1개 CHI Spin N Curl Rotating Curler Power Cord Replacement: 3 단계, 이미지 2개 중 2개
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Power Cord Replacement: 4 단계, 이미지 2개 중 1개 CHI Spin N Curl Rotating Curler Power Cord Replacement: 4 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Power Cord Replacement: 5 단계, 이미지 3개 중 1개 CHI Spin N Curl Rotating Curler Power Cord Replacement: 5 단계, 이미지 3개 중 2개 CHI Spin N Curl Rotating Curler Power Cord Replacement: 5 단계, 이미지 3개 중 3개
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jacqueline Ramirez
회원 가입일: 10/26/22
175 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-7, Petersen Fall 2022 UMass Dartmouth, Team 2-7, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G7
3 회원들
안내서 6개를 작성함
댓글 한 개
but where to get new cable?
Kristián Feldsam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 435
