주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 30 Remote Control Socket Replacement
필요한 것
    1. Canon EOS 30 Remote Control Socket Replacement, Front Panel: 1 단계, 이미지 1개 중 1개
      • Remove the two 4.8 mm black screws above the lens on the front of the camera.
      댓글 쓰기
    2. Canon EOS 30 Remote Control Socket Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
      댓글 쓰기
    3. Canon EOS 30 Remote Control Socket Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the 4.8 mm black screw on the left side of the camera.
      댓글 쓰기
    4. Canon EOS 30 Remote Control Socket Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the front panel by lifting it away from the camera's body.
      댓글 쓰기
    1. Canon EOS 30 Remote Control Socket Replacement, Bottom Panel: 5 단계, 이미지 1개 중 1개
      • Remove seven 4.25 mm black screws on the bottom panel.
      댓글 쓰기
    2. Canon EOS 30 Remote Control Socket Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the bottom panel.
      댓글 쓰기
    1. Canon EOS 30 Remote Control Socket Replacement, Side Panel With Remote Control Socket: 7 단계, 이미지 1개 중 1개
      • Remove two 6.5 mm black screws from the panel.
      댓글 쓰기
    2. Canon EOS 30 Remote Control Socket Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the plastic remote control socket cap by pulling it straight out.
      댓글 쓰기
    3. Canon EOS 30 Remote Control Socket Replacement: 9 단계, 이미지 2개 중 1개 Canon EOS 30 Remote Control Socket Replacement: 9 단계, 이미지 2개 중 2개
      • Slide the panel toward the bottom of the camera to remove.
      댓글 쓰기
    4. Canon EOS 30 Remote Control Socket Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the single 4.8 silver screw from the control socket.
      댓글 쓰기
    5. Canon EOS 30 Remote Control Socket Replacement: 11 단계, 이미지 2개 중 1개 Canon EOS 30 Remote Control Socket Replacement: 11 단계, 이미지 2개 중 2개
      • The control socket is now secure by three wires.
      • Desolder connections to replace the remote control socket.
      댓글 쓰기
    1. Canon EOS 30 Remote Control Socket Replacement, Remote Control Socket: 12 단계, 이미지 1개 중 1개
      • Remove one 4.8 mm silver screw securing Remote Control Socket to camera.
      댓글 쓰기
    2. Canon EOS 30 Remote Control Socket Replacement: 13 단계, 이미지 2개 중 1개 Canon EOS 30 Remote Control Socket Replacement: 13 단계, 이미지 2개 중 2개
      • Remote Control Socket is now secured by 3 wires.
      • Desolder connections to replace Remote Control Socket.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Antonia
회원 가입일: 04/17/11
124 평판
안내서 2개를 작성함
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 회원
CPSU-REGAN-S11S8G8
5 회원들
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 49
전체 시간: 3,467
