주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 30 Side Panel With Remote Control Socket Replacement
필요한 것
    1. Canon EOS 30 Side Panel With Remote Control Socket Replacement, Front Panel: 1 단계, 이미지 1개 중 1개
      • Remove the two 4.8 mm black screws above the lens on the front of the camera.
      댓글 쓰기
    2. Canon EOS 30 Side Panel With Remote Control Socket Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
      댓글 쓰기
    3. Canon EOS 30 Side Panel With Remote Control Socket Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the 4.8 mm black screw on the left side of the camera.
      댓글 쓰기
    4. Canon EOS 30 Side Panel With Remote Control Socket Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the front panel by lifting it away from the camera's body.
      댓글 쓰기
    1. Canon EOS 30 Side Panel With Remote Control Socket Replacement, Bottom Panel: 5 단계, 이미지 1개 중 1개
      • Remove seven 4.25 mm black screws on the bottom panel.
      댓글 쓰기
    2. Canon EOS 30 Side Panel With Remote Control Socket Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the bottom panel.
      댓글 쓰기
    1. Canon EOS 30 Side Panel With Remote Control Socket Replacement, Side Panel With Remote Control Socket: 7 단계, 이미지 1개 중 1개
      • Remove two 6.5 mm black screws from the panel.
      댓글 쓰기
    2. Canon EOS 30 Side Panel With Remote Control Socket Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the plastic remote control socket cap by pulling it straight out.
      댓글 쓰기
    3. Canon EOS 30 Side Panel With Remote Control Socket Replacement: 9 단계, 이미지 2개 중 1개 Canon EOS 30 Side Panel With Remote Control Socket Replacement: 9 단계, 이미지 2개 중 2개
      • Slide the panel toward the bottom of the camera to remove.
      댓글 쓰기
    4. Canon EOS 30 Side Panel With Remote Control Socket Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the single 4.8 silver screw from the control socket.
      댓글 쓰기
    5. Canon EOS 30 Side Panel With Remote Control Socket Replacement: 11 단계, 이미지 2개 중 1개 Canon EOS 30 Side Panel With Remote Control Socket Replacement: 11 단계, 이미지 2개 중 2개
      • The control socket is now secure by three wires.
      • Desolder connections to replace the remote control socket.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
14다른 기여자 명과 함께
Sterling Vinson
회원 가입일: 04/17/11
314 평판
안내서 5개를 작성함
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 회원
CPSU-REGAN-S11S8G8
5 회원들
안내서 22개를 작성함
3가이드 댓글
i have this camera and the door that holds the film in will not stay closed because the plastic piece has broken at the release point. Which piece is it that I need to replace?
luederscoupons - 답글 공유
That's a bit of a bugger. The piece that's broken off is most likely the little "hook" on the "door" (the proper name of this "door" would be "back").
Since this little hook is integral with the back, you'd have to replace the entire back.
If you still have the piece that has broken off, it may be possible to glue it back in place, but you'd have to reinforce it with e.g. a small piece of aluminium sheet cut from a soft drink can or something like that. Use cyanoacrylate glue (otherwise known as "superglue") and make sure the pieces are clean and fit perfectly before applying the glue. You need only a tiny drop.
Flying Dutchman - 답글 공유
The EOS 30 is a film camera and therefore does not have an A/V Port, since it does neither Audio nor Video. The socket near the bottom on the grip side is for a wired remote control.
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 43
전체 시간: 2,460
