주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A80 LCD Screen Replacement
필요한 것
    1. Canon PowerShot A80 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
      • Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
      댓글 쓰기
    2. Canon PowerShot A80 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot A80 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Using a Phillips #00 screwdriver, remove the 2.9 mm screws on the other side of the screen to separate the front and back covers.
      • To access the second screw, rotate the screen 90° so that it faces upwards.
      댓글 쓰기
    3. Canon PowerShot A80 LCD Screen Replacement: 3 단계, 이미지 3개 중 1개 Canon PowerShot A80 LCD Screen Replacement: 3 단계, 이미지 3개 중 2개 Canon PowerShot A80 LCD Screen Replacement: 3 단계, 이미지 3개 중 3개
      • Gently remove the front and back covers from the screen.
      • Peel back the plastic circuit cover.
      댓글 쓰기
    4. Canon PowerShot A80 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Pull the screen away from the base.
      • This will take some force, but remember to handle with care.
      • If a small metal piece between the screen cover and the screen falls out during repair, replace it with the rounded corners facing away from the screen during reassembly.
      댓글 쓰기
    5. Canon PowerShot A80 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Unplug the ribbon cable connected to the circuit board latch.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
15다른 기여자 명과 함께
konrad
회원 가입일: 01/11/11
220 평판
안내서 3개를 작성함
Cal Poly, Team 7-31, Regan Winter 2011 Cal Poly, Team 7-31, Regan Winter 2011 회원
CPSU-REGAN-W11S7G31
6 회원들
안내서 18개를 작성함
2가이드 댓글
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - 답글 공유
Do you know where can I find a replacement LCD over internet?
Paolo Gai - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 78
전체 시간: 5,094
