주요 콘텐츠로 건너뛰기
Canon PowerShot SD1400 IS Motherboard Replacement
Faris Rezwan
Faris Rezwan5 다른 기여자
최종 수정일 May 7, 2024
20 - 30 분
조정
The motherboard can be damaged because of overheat and a short circuit which can cause the camera to stop working. This guide will show how to replace the motherboard in the device.
필요한 것
부품
도구
더보기...
  1. Canon PowerShot SD1400 IS Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Canon PowerShot SD1400 IS Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Canon PowerShot SD1400 IS Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove two 2mm Phillips #00 screws on both sides of the camera.
  2. Canon PowerShot SD1400 IS Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 4mm Phillips #000 screw from the bottom.
  3. Canon PowerShot SD1400 IS Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the front face panel of the camera.
  4. Canon PowerShot SD1400 IS Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the rear panel of the camera by using hand with firm pressure.
    • The user interface panel, side and bottom panel of the camera may fall down by itself while you are taking the rear panel of the camera.
  5. Canon PowerShot SD1400 IS Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 3mm Phillips #000 screw from the top of the camera.
  6. Canon PowerShot SD1400 IS Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Canon PowerShot SD1400 IS Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Canon PowerShot SD1400 IS Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Pry the three golden ribbons off the motherboard using a plastic opening tool.
  7. Canon PowerShot SD1400 IS Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Canon PowerShot SD1400 IS Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Canon PowerShot SD1400 IS Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
    • Once released, the small black tab will point straight away from the front face of the camera and the golden film will no longer be attached to the motherboard.
  8. Canon PowerShot SD1400 IS Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Canon PowerShot SD1400 IS Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Unplug the small chip from the face of the camera using a pair of tweezers.
  9. Canon PowerShot SD1400 IS Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Canon PowerShot SD1400 IS Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Canon PowerShot SD1400 IS Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the three 3mm Phillips #000 screws from the motherboard.
  10. Canon PowerShot SD1400 IS Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the 3mm Phillips #000 screw from the rear face of the camera.
  11. Canon PowerShot SD1400 IS Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the top panel from the camera.
  12. Canon PowerShot SD1400 IS Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Canon PowerShot SD1400 IS Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the motherboard.
결론
작성자
5다른 기여자 명과 함께
Faris Rezwan
회원 가입일: 05/21/18
457 평판
안내서 2개를 작성함
IUPUI, Team S1-G2, Harley Spring 2018 IUPUI, Team S1-G2, Harley Spring 2018 회원
IUPUI-HARLEY-S18S1G2
7 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 470
