주요 콘텐츠로 건너뛰기
Canon PowerShot SD1400 IS User Interface Panel Replacement
Braxton Beal
Braxton Beal4 다른 기여자
최종 수정일 September 18, 2019
10 - 15 분
쉬움
The buttons on the user interface panel can become broken or stuck. This guide will show how to replace the user interface panel on the Canon PowerShot SD1400 IS.
필요한 것
부품
도구
더보기...
  1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: 1 단계, 이미지 3개 중 1개 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: 1 단계, 이미지 3개 중 2개 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: 1 단계, 이미지 3개 중 3개
    • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
  2. Canon PowerShot SD1400 IS User Interface Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS User Interface Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the front face panel of the camera by hand using firm pressure.
    • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
  4. Canon PowerShot SD1400 IS User Interface Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the rear panel of the camera by hand using firm pressure.
  5. Canon PowerShot SD1400 IS User Interface Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
    • Replace the user interface panel by setting it in position.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Braxton Beal
회원 가입일: 01/30/18
702 평판
안내서 3개를 작성함
Baylor, Team S1-G3, Johnson Spring 2018 Baylor, Team S1-G3, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G3
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 18
전체 시간: 333
