주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot SX50 HS Flash Bulb Replacement
필요한 것
    1. Canon PowerShot SX50 HS Flash Bulb Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Locate the battery compartment on the bottom of the camera.
      • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
      댓글 쓰기
    2. Canon PowerShot SX50 HS Flash Bulb Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
      • Now remove the battery pack from the camera with your fingers.
      댓글 쓰기
    1. Canon PowerShot SX50 HS Flash Bulb Replacement, Flash Bulb: 3 단계, 이미지 1개 중 1개
      • Lift up the flash as you would when using and activating the flash.
      댓글 쓰기
    2. Canon PowerShot SX50 HS Flash Bulb Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot SX50 HS Flash Bulb Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the two Phillips #000 screws, length 3 mm, on both sides of the flash.
      댓글 쓰기
    3. Canon PowerShot SX50 HS Flash Bulb Replacement: 5 단계, 이미지 1개 중 1개
      • Pull off the back encasement of the flash with your fingers. The internals will now become visible.
      댓글 쓰기
    4. Canon PowerShot SX50 HS Flash Bulb Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot SX50 HS Flash Bulb Replacement: 6 단계, 이미지 2개 중 2개
      • Locate the black, white and the beige wires. Desolder these wires at the point of connection with the bulb.
      • See the guide on this link for soldering and desoldering.
      댓글 쓰기
    5. Canon PowerShot SX50 HS Flash Bulb Replacement: 7 단계, 이미지 3개 중 1개 Canon PowerShot SX50 HS Flash Bulb Replacement: 7 단계, 이미지 3개 중 2개 Canon PowerShot SX50 HS Flash Bulb Replacement: 7 단계, 이미지 3개 중 3개
      • Once the wires have been desoldered, pull the flash out of its casing.
      • Remove one end of the rubber band holding the bulb in place.
      • Slide the bulb out of the flash.
      댓글 쓰기
    6. Canon PowerShot SX50 HS Flash Bulb Replacement: 8 단계, 이미지 2개 중 1개 Canon PowerShot SX50 HS Flash Bulb Replacement: 8 단계, 이미지 2개 중 2개
      • Completely remove the rubber band from the flash bulb.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Daniel Gurrola
회원 가입일: 04/01/15
273 평판
안내서 2개를 작성함
Cal Poly, Team 12-7, Lancaster Spring 2015 Cal Poly, Team 12-7, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G7
5 회원들
안내서 10개를 작성함
5가이드 댓글
Hello! excellent explanation . Thank you very much! I have a question : could you tell me where I can buy the replacement lamp ? I already tried searching online but can not find anywhere that sells it. Thank you very much , greetings !
German Witt - 답글 공유
I need a bulb, no one can tell where you can find a bulb, and it says no parts needed. that's stupid since you need a replacement bulb that you can't find. without it all this is useless.
buborek1974 - 답글 공유
Where can i found the replacement bulb???Why it is written that there is no need for replacement parts?
Audrey - 답글 공유
Do you know where I can purchase a bulb to go with this type of camera? I can not find just the bulb. Please HELP!
arusso4e - 답글 공유
Hi, i need know if this piece is the correct
https://es.aliexpress.com/item/328403224...
Thanks
Fredy Cardenas Bolaños - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 45
전체 시간: 6,599
