주요 콘텐츠로 건너뛰기
Canon Powershot A70 Rear Exterior Panel Replacement
Shalan Ertis
Shalan Ertis14 다른 기여자
최종 수정일 February 19, 2025
15 분
쉬움
더 나은 이미지가 필요함
This guide explains the location of exterior screws and the process to remove the rear panel of the Canon Powershot A70 camera. This is often the first step to many fixes for this device, and the rear panel itself will need to be replaced after years of use. This can be performed with easy-to-use tools and requires no special skills to complete.
필요한 것
도구
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
더보기...
  1. Canon Powershot A70 Rear Exterior Panel Replacement, Rear Exterior Panel: 1 단계, 이미지 1개 중 1개
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  2. Canon Powershot A70 Rear Exterior Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  3. Canon Powershot A70 Rear Exterior Panel Replacement: 3 단계, 이미지 3개 중 1개 Canon Powershot A70 Rear Exterior Panel Replacement: 3 단계, 이미지 3개 중 2개 Canon Powershot A70 Rear Exterior Panel Replacement: 3 단계, 이미지 3개 중 3개
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  4. Canon Powershot A70 Rear Exterior Panel Replacement: 4 단계, 이미지 2개 중 1개 Canon Powershot A70 Rear Exterior Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  5. Canon Powershot A70 Rear Exterior Panel Replacement: 5 단계, 이미지 1개 중 1개
    • The interior of the camera should look like this.
결론
작성자
14다른 기여자 명과 함께
Shalan Ertis
회원 가입일: 01/26/10
83 평판
안내서 3개를 작성함
Cal Poly, Team 14-40, Regan Winter 2010 Cal Poly, Team 14-40, Regan Winter 2010 회원
CPSU-REGAN-W10S14G40
5 회원들
안내서 16개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 3,293
