주요 콘텐츠로 건너뛰기
Canon Powershot SX500 IS LCD Screen Replacement
Marty Woolf
Marty Woolf3 다른 기여자
최종 수정일 June 24, 2015
10 분
조정
In order to replace the LCD screen you will need a PH00 screwdriver and a spudger. Be careful with the connections to the board it is easy to break.
필요한 것
도구
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
더보기...
  1. Canon Powershot SX500 IS LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: 4 단계, 이미지 3개 중 1개 Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: 4 단계, 이미지 3개 중 2개 Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: 4 단계, 이미지 3개 중 3개
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
  7. Canon Powershot SX500 IS LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Canon Powershot SX500 IS LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS LCD Screen Replacement, Control Dial: 9 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
  13. Canon Powershot SX500 IS LCD Screen Replacement, LCD Screen: 13 단계, 이미지 1개 중 1개
    • Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Marty Woolf
회원 가입일: 04/07/15
173 평판
안내서 1개를 작성함
댓글 2개
Hello, my LCD screen is not working. One day it was fine, the next day I powered my camera and the LCD screen is only half visible. I appreciate the directions on how to take out/repair LCD screen, though where am I able to purchase a new LCD screen for my PowerShot SX500IS? Many thanks.
dana karavias - 답글
Disassembly of SX510HS is exactly the same. No special pry tool is required - it is very easy to remove the cover with your fingernail. Replacement LCD on Aliexpress is 8-12 USD.
Witold Kardyś - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 13
전체 시간: 1,189
