주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Casio CTK-501 Battery Connection Replacement
필요한 것
    1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: 1 단계, 이미지 2개 중 1개 Casio CTK-501 Battery Connection Replacement, Bottom Panel: 1 단계, 이미지 2개 중 2개
      • Flip the keyboard over so that the bottom is facing up.
      • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
      댓글 쓰기
    2. Casio CTK-501 Battery Connection Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the bottom panel by lifting and pulling it towards yourself.
      댓글 쓰기
    3. Casio CTK-501 Battery Connection Replacement: 3 단계, 이미지 2개 중 1개 Casio CTK-501 Battery Connection Replacement: 3 단계, 이미지 2개 중 2개
      • Flip open the top half of the keyboard.
      • Set the keyboard onto the bottom half with the internal parts facing up.
      • Be careful not to let the bottom drop.
      댓글 쓰기
    1. Casio CTK-501 Battery Connection Replacement, Battery Connection: 4 단계, 이미지 1개 중 1개
      • Plug in the soldering iron.
      • Set the soldering iron somewhere safe, where it can't catch anything on fire.
      • Unscrew the top green circuit board with black and red wires running through it.
      댓글 쓰기
    2. Casio CTK-501 Battery Connection Replacement: 5 단계, 이미지 1개 중 1개
      • Set the circuit board somewhere flat so it is safe to solder.
      댓글 쓰기
    3. Casio CTK-501 Battery Connection Replacement: 6 단계, 이미지 1개 중 1개
      • Heat up the solder covering the end of the wires connected to the circuit board.
      • Once the solder melts, remove the wires from the circuit board.
      댓글 쓰기
    4. Casio CTK-501 Battery Connection Replacement: 7 단계, 이미지 1개 중 1개
      • Melt new solder with your soldering iron.
      • Then apply it over the tip of the wire resting on the circuit board.
      댓글 쓰기
    5. Casio CTK-501 Battery Connection Replacement: 8 단계, 이미지 1개 중 1개
      • Once the wires are firmly attached, screw the circuit board back into the keyboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jimmy Winne
회원 가입일: 10/04/12
578 평판
안내서 6개를 작성함
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G16
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 46
전체 시간: 5,617
