주요 콘텐츠로 건너뛰기
Chromebook x360 14-da0011dx Fan Replacement
Jake Williamson
Jake Williamson2 다른 기여자
최종 수정일 May 16, 2023
20 - 25 분
조정
This guide will walk users through replacing the cooling fan of the Chromebook x360 14-da0011dx. Fans accumulate debris and dust over time, causing malfunction or reduced function. If possible, clean fan debris and retry connection before replacing the fan altogether.
필요한 것
도구
더보기...
  1. Chromebook x360 14-da0011dx Fan Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Fan Replacement: 2 단계, 이미지 2개 중 1개 Chromebook x360 14-da0011dx Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Fan Replacement: 3 단계, 이미지 3개 중 1개 Chromebook x360 14-da0011dx Fan Replacement: 3 단계, 이미지 3개 중 2개 Chromebook x360 14-da0011dx Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Fan Replacement, Battery: 4 단계, 이미지 2개 중 1개 Chromebook x360 14-da0011dx Fan Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the cable attached to the battery.
  5. Chromebook x360 14-da0011dx Fan Replacement: 5 단계, 이미지 2개 중 1개 Chromebook x360 14-da0011dx Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the battery out of the chassis.
  7. Chromebook x360 14-da0011dx Fan Replacement, Fan: 7 단계, 이미지 1개 중 1개
    • Remove the two 3.0 mm Phillips #1 screws holding the fan in place.
  8. Chromebook x360 14-da0011dx Fan Replacement: 8 단계, 이미지 2개 중 1개 Chromebook x360 14-da0011dx Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the fan cable from the motherboard.
    • Carefully remove the fan from the computer.
    • Be careful when removing the fan, as it sits under one of the CPU heat pipes and tucks under the ribbon cable that runs to the I/O board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jake Williamson
회원 가입일: 02/14/23
559 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 238
