주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chromo Noria Touch Screen Replacement
필요한 것
    1. Chromo Noria Touch Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Chromo Noria Touch Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Chromo Noria Touch Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
      • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
      • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
      댓글 쓰기
    2. Chromo Noria Touch Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully turn the device over.
      • Lay the back panel aside so you can see the device's parts.
      댓글 쓰기
    1. Chromo Noria Touch Screen Replacement, Battery: 3 단계, 이미지 3개 중 1개 Chromo Noria Touch Screen Replacement, Battery: 3 단계, 이미지 3개 중 2개 Chromo Noria Touch Screen Replacement, Battery: 3 단계, 이미지 3개 중 3개
      • Place your finger at the end of the tape closest to the battery.
      • Peel the tape towards the flex cables to free the battery wires.
      댓글 쓰기
    2. Chromo Noria Touch Screen Replacement: 4 단계, 이미지 3개 중 1개 Chromo Noria Touch Screen Replacement: 4 단계, 이미지 3개 중 2개 Chromo Noria Touch Screen Replacement: 4 단계, 이미지 3개 중 3개
      • Using the spudger tool, place the tool along an edge of the battery.
      • Be careful not to bend or break the battery! Batteries contain hazards materials.
      • Move the spudger around the edges of the battery to detach it from the tablet.
      댓글 쓰기
    3. Chromo Noria Touch Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
      • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
      • Remove the battery.
      댓글 쓰기
    1. Chromo Noria Touch Screen Replacement, Camera: 6 단계, 이미지 2개 중 1개 Chromo Noria Touch Screen Replacement, Camera: 6 단계, 이미지 2개 중 2개
      • Carefully detach one side of the black tape from the board.
      댓글 쓰기
    2. Chromo Noria Touch Screen Replacement: 7 단계, 이미지 2개 중 1개 Chromo Noria Touch Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
      • Now, the flexing cable is ready to be removed.
      댓글 쓰기
    3. Chromo Noria Touch Screen Replacement: 8 단계, 이미지 2개 중 1개 Chromo Noria Touch Screen Replacement: 8 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using a pair of tweezers, hold the flexing cable right below the black connector.
      • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
      댓글 쓰기
    1. Chromo Noria Touch Screen Replacement, Speaker: 9 단계, 이미지 1개 중 1개
      • Using your spudger tool, remove speaker from the backboard.
      댓글 쓰기
    2. Chromo Noria Touch Screen Replacement: 10 단계, 이미지 2개 중 1개 Chromo Noria Touch Screen Replacement: 10 단계, 이미지 2개 중 2개
      • Using the spudger tool, detach the speaker from the back of the screen.
      댓글 쓰기
    3. Chromo Noria Touch Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Using a Soldering Iron, desolder both wires from the motherboard.
      댓글 쓰기
    1. Chromo Noria Touch Screen Replacement, Motherboard: 12 단계, 이미지 2개 중 1개 Chromo Noria Touch Screen Replacement, Motherboard: 12 단계, 이미지 2개 중 2개
      • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
      댓글 쓰기
    2. Chromo Noria Touch Screen Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the three pieces of tap keeping the wires in place.
      댓글 쓰기
    3. Chromo Noria Touch Screen Replacement: 14 단계, 이미지 3개 중 1개 Chromo Noria Touch Screen Replacement: 14 단계, 이미지 3개 중 2개 Chromo Noria Touch Screen Replacement: 14 단계, 이미지 3개 중 3개
      • Place a spudger on the small black pins on either side of the flex cables.
      • Gently push the spudger towards the back of flex cables to unlock the flex cable.
      • Remove the flex cables from their insert.
      댓글 쓰기
    4. Chromo Noria Touch Screen Replacement: 15 단계, 이미지 1개 중 1개
      • Desolder the eight connections.
      댓글 쓰기
    5. Chromo Noria Touch Screen Replacement: 16 단계, 이미지 1개 중 1개
      • Lift the motherboard to remove.
      댓글 쓰기
    1. Chromo Noria Touch Screen Replacement, Touch Screen: 17 단계, 이미지 3개 중 1개 Chromo Noria Touch Screen Replacement, Touch Screen: 17 단계, 이미지 3개 중 2개 Chromo Noria Touch Screen Replacement, Touch Screen: 17 단계, 이미지 3개 중 3개
      • Apply downward pressure to each of the clips that hold the touchscreen to the plastic surround.
      • Careful to not apply so much pressure as to break the device! These hinges should move easily.
      • Work your way around the device in a clockwise motion as you progress.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nick Rohn
회원 가입일: 10/30/16
475 평판
안내서 3개를 작성함
Baylor, Team 5-6, Williams Fall 2016 Baylor, Team 5-6, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G6
3 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 32
전체 시간: 626
