주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cineyo BT-03 Device Audio Jack Replacement
필요한 것
    1. Cineyo BT-03 Device Audio Jack Replacement, Cineyo BT-03 Device Disassembly: 1 단계, 이미지 3개 중 1개 Cineyo BT-03 Device Audio Jack Replacement, Cineyo BT-03 Device Disassembly: 1 단계, 이미지 3개 중 2개 Cineyo BT-03 Device Audio Jack Replacement, Cineyo BT-03 Device Disassembly: 1 단계, 이미지 3개 중 3개
      • Remove the top (button side) rubber cover using your hands.
      댓글 쓰기
    2. Cineyo BT-03 Device Audio Jack Replacement: 2 단계, 이미지 2개 중 1개 Cineyo BT-03 Device Audio Jack Replacement: 2 단계, 이미지 2개 중 2개
      • Flip over the device and remove the bottom rubber cover using your hands.
      댓글 쓰기
    3. Cineyo BT-03 Device Audio Jack Replacement: 3 단계, 이미지 3개 중 1개 Cineyo BT-03 Device Audio Jack Replacement: 3 단계, 이미지 3개 중 2개 Cineyo BT-03 Device Audio Jack Replacement: 3 단계, 이미지 3개 중 3개
      • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
      댓글 쓰기
    4. Cineyo BT-03 Device Audio Jack Replacement: 4 단계, 이미지 3개 중 1개 Cineyo BT-03 Device Audio Jack Replacement: 4 단계, 이미지 3개 중 2개 Cineyo BT-03 Device Audio Jack Replacement: 4 단계, 이미지 3개 중 3개
      • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
      • The cover should remain as one solid piece.
      댓글 쓰기
    5. Cineyo BT-03 Device Audio Jack Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
      댓글 쓰기
    6. Cineyo BT-03 Device Audio Jack Replacement: 6 단계, 이미지 1개 중 1개
      • Gently pull apart the two sections of the device.
      댓글 쓰기
    1. Cineyo BT-03 Device Audio Jack Replacement, Audio Jack: 7 단계, 이미지 1개 중 1개
      • Disconnect all wires from the top of the circuit board.
      댓글 쓰기
    2. Cineyo BT-03 Device Audio Jack Replacement: 8 단계, 이미지 1개 중 1개
      • Using a small Philips head screwdriver, remove the two 5 mm screws from the main circuit board.
      댓글 쓰기
    3. Cineyo BT-03 Device Audio Jack Replacement: 9 단계, 이미지 1개 중 1개
      • Use the soldering iron to melt the two contact points that attach the wires to the rear side of the circuit board.
      • This will require soldering off the wires connecting the bottom of the circuit board to the device. iFixit's Soldering Guide is available to aid in soldering.
      댓글 쓰기
    4. Cineyo BT-03 Device Audio Jack Replacement: 10 단계, 이미지 2개 중 1개 Cineyo BT-03 Device Audio Jack Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the circuit board from the device.
      댓글 쓰기
    5. Cineyo BT-03 Device Audio Jack Replacement: 11 단계, 이미지 1개 중 1개
      • Using a soldering iron, remove the audio jack from the circuit board.
      • There are four contact points attaching the audio jack.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Rene Klopf
회원 가입일: 01/30/17
487 평판
안내서 4개를 작성함
팀
Baylor, Team 8-3, Whitney Spring 2017 Baylor, Team 8-3, Whitney Spring 2017 회원
BU-WHITNEY-S17S8G3
5 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 14
지난 30일: 78
전체 시간: 495
