주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Coby KYROS MID7125 Motherboard Replacement
필요한 것
    1. Coby KYROS MID7125 Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
      • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel
      댓글 쓰기
    2. Coby KYROS MID7125 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Coby KYROS MID7125 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Coby KYROS MID7125 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger
      • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
      • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
      • Desolder fifth ribbon cable with soldering station.
      댓글 쓰기
    3. Coby KYROS MID7125 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Coby KYROS MID7125 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Coby KYROS MID7125 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
      • Desolder 2 speaker wires
      • Desolder antenna wire
      • Desolder microphone wire
      • Remove all wires you just desoldered.
      댓글 쓰기
    4. Coby KYROS MID7125 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Desolder the battery wires.
      • If soldering is new to you, then check out this useful guide on soldering and desoldering connections.
      • Remove the battery.
      댓글 쓰기
    5. Coby KYROS MID7125 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Unscrew 4 screws connecting around mother board using the J0 Phillips head screwdriver.
      댓글 쓰기
    6. Coby KYROS MID7125 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Coby KYROS MID7125 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Use plastic spudger to take off motherboard by lifting off right hand side and pulling sideways.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Nicole Connelly
회원 가입일: 10/20/16
1 평판
안내서 3개를 작성함
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G2
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 29
전체 시간: 552
