주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Coby KYROS MID7125 Side Lock Button Replacement
필요한 것
    1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: 1 단계, 이미지 1개 중 1개
      • Begin by removing back panel using the large opening tool.
      댓글 쓰기
    2. Coby KYROS MID7125 Side Lock Button Replacement: 2 단계, 이미지 3개 중 1개 Coby KYROS MID7125 Side Lock Button Replacement: 2 단계, 이미지 3개 중 2개 Coby KYROS MID7125 Side Lock Button Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
      댓글 쓰기
    3. Coby KYROS MID7125 Side Lock Button Replacement: 3 단계, 이미지 1개 중 1개
      • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
      • Review Battery Replacement for details on how to remove battery.
      댓글 쓰기
    4. Coby KYROS MID7125 Side Lock Button Replacement: 4 단계, 이미지 2개 중 1개 Coby KYROS MID7125 Side Lock Button Replacement: 4 단계, 이미지 2개 중 2개
      • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
      댓글 쓰기
    5. Coby KYROS MID7125 Side Lock Button Replacement: 5 단계, 이미지 1개 중 1개
      • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
      • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
      댓글 쓰기
    6. Coby KYROS MID7125 Side Lock Button Replacement: 6 단계, 이미지 1개 중 1개
      • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
      • Reverse steps 1-5 to reassemble.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Benjamin Foley
회원 가입일: 10/20/16
125 평판
안내서 1개를 작성함
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G2
3 회원들
안내서 10개를 작성함
1가이드 댓글
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 27
전체 시간: 484
