주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Comfort Zone CZ6C Switch Replacement
필요한 것
    1. Comfort Zone CZ6C Switch Replacement, Switch: 1 단계, 이미지 3개 중 1개 Comfort Zone CZ6C Switch Replacement, Switch: 1 단계, 이미지 3개 중 2개 Comfort Zone CZ6C Switch Replacement, Switch: 1 단계, 이미지 3개 중 3개
      • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
      • Before replacing your switch, learn how to solder using the How To Solder and Desolder Connections Guide.
      • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
      댓글 쓰기
    2. Comfort Zone CZ6C Switch Replacement: 2 단계, 이미지 2개 중 1개 Comfort Zone CZ6C Switch Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the plastic cover on the switch by pulling it apart from the the back panel.
      댓글 쓰기
    3. Comfort Zone CZ6C Switch Replacement: 3 단계, 이미지 1개 중 1개
      • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
      • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
      • Disconnect the gray power wire from the switch by desoldering the connection.
      댓글 쓰기
    4. Comfort Zone CZ6C Switch Replacement: 4 단계, 이미지 2개 중 1개 Comfort Zone CZ6C Switch Replacement: 4 단계, 이미지 2개 중 2개
      • Cut the green and yellow wire as close to the switch connection as possible.
      댓글 쓰기
    5. Comfort Zone CZ6C Switch Replacement: 5 단계, 이미지 3개 중 1개 Comfort Zone CZ6C Switch Replacement: 5 단계, 이미지 3개 중 2개 Comfort Zone CZ6C Switch Replacement: 5 단계, 이미지 3개 중 3개
      • Strip the green and yellow wire about two centimeters from where it was just cut.
      댓글 쓰기
    6. Comfort Zone CZ6C Switch Replacement: 6 단계, 이미지 3개 중 1개 Comfort Zone CZ6C Switch Replacement: 6 단계, 이미지 3개 중 2개 Comfort Zone CZ6C Switch Replacement: 6 단계, 이미지 3개 중 3개
      • Unscrew the switch from the back panel and remove it.
      댓글 쓰기
    7. Comfort Zone CZ6C Switch Replacement: 7 단계, 이미지 3개 중 1개 Comfort Zone CZ6C Switch Replacement: 7 단계, 이미지 3개 중 2개 Comfort Zone CZ6C Switch Replacement: 7 단계, 이미지 3개 중 3개
      • After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
James Abundis
회원 가입일: 04/08/15
169 평판
안내서 1개를 작성함
Cal Poly, Team 17-5, Forte Spring 2015 Cal Poly, Team 17-5, Forte Spring 2015 회원
CPSU-FORTE-S15S17G5
4 회원들
안내서 7개를 작성함
1가이드 댓글
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
Michael Drasic - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 39
전체 시간: 2,811
